FlatlineEF9's W210 Rebuild thread
Old Oct 26, 2015 | 04:03 PM
  #201
Nashville's Avatar
2001 E320
beautiful! notice a difference in stopping power? pedal feel?
Old Oct 26, 2015 | 07:08 PM
  #202
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
I noticed a much bigger difference upgrading the front brakes to AMG, but with the rears, it was maybe like another 10% difference. It still stops smooth but much more bite. Pedal feel is still soft but now i barely have to touch it to slow the car...just resting my foot on the pedal will usually do the job.
Old Oct 27, 2015 | 01:58 AM
  #203
autopressagency's Avatar
W210 E430 Avantgarde
Good Job! Car looks great with all mods.
Respect...
Old Oct 27, 2015 | 01:41 PM
  #204
Respect...
Thank you
Old Nov 10, 2015 | 09:25 PM
  #205
Had the car detailed this weekend. My buddy did a wash, claybar, polish, and opticoat. Looks and feels amazing!
Old Nov 27, 2015 | 01:20 PM
  #206
Not mod related but had a few failures last week. PSE pump is broken and needs to be replaced. Also my aux fans squeaked like a ***** then crapped out on me too. Oh joy. lol. Not sure if i am going to go with OEM fans or throw 2 flex a lites in there
Old Dec 31, 2015 | 08:31 PM
  #207
Not really mod related but since september i have been using the car on the daily and now a TON of problems have presented.
1) Reverse lights stopped working
2) wheel bearings (all 4) i think are going out
3) shifter mechanism or bushings going
4) parking lights stuck on
5) aux fans stopped working
6) cluster pixels stopped working
So to start to tackle the problems
1) i just unplugged the reverse lights for now. I think it is probably the reverse selector switch inside the shifter...i will look into it in a few weeks but i have more pressing issues
2) The bearing noise is pretty bad. 15mph is the worst and above 60mph is pretty bad too. Im sure being slammed for over 10 years isnt good for bearings. Ordered new front hubs and rear bearing kit so i will post pics of those being replaced next week.
4) Thought it was the PSE pump, replaced it...and the lights were still on. So i ended up replacing the light switch. Heres a pic of the dash apart.
Pretty simple job and im glad total to fix my problem was less than 200 bucks.
5) Got some depo aux fans from amazon. They got slightly damaged in shipping but with a little of bending of the bracket and housing they dropped right in and now my car isnt overheating in traffic.
6) Bought the cluster ribbon repair kit off ebay (the tape one). At first it didnt work, but then i took the cluster apart again and scraped the ribbon down with a flathead screwdriver and now all the pixels work $25 fix.
Old Dec 31, 2015 | 08:33 PM
  #208
Some pics of her out and about.
Old Jan 7, 2016 | 09:02 PM
  #209
On to tackle the bearings. Front hub replacements came in so i got right to it. The spindles were nice and smooth but had a little bit of scoring on one side. Gonna drive it for a few days then double check the bearing play.
Still waiting on the rears from the dealer, which are on back order. I figure if im going to take all the time to swap out the rear bearings, i might as well get genuine MB...i hope they will last longer than the aftermarket ones.
Old Feb 22, 2016 | 01:00 PM
  #210
phokingb's Avatar
cl600
what are the offsets on your wheels u have now? im thinking about getting some 19x9.5 and 19x10.5 rears with a +22 offset and was wondering if u think they would sit flush
Old Feb 22, 2016 | 02:24 PM
  #211
As far as i can recall, they are et 35 front and back...but im not 100% sure on this. I did fine tuning on mine. Had them installed with no spacers then spaced them out accordingly and tuned with tire stretch and camber arms.
18x8.5 front and 18x9.5 rear on mine. ET35 with 30mm spacers on front and 15mm spacers on rear. Will make my front offset +5 and rear is +20
tire size is 225 40 front and 245 40 rear.
So to answer your question, the rear should line up nice and the front should be a little sunk, assuming you run a stretched tire.
Old Feb 23, 2016 | 12:32 AM
  #212
phokingb's Avatar
cl600
Thanks for the reply man... One last question though, what tire sizes should I run if I do go with this setup?
Old Feb 23, 2016 | 01:15 PM
  #213
R2dMax's Avatar
87 190e 2.3-16v Cosworth; 2000 E320 Saloon
Just curious how long you had this before you had to replace the bearings. (Time/miles)
Old Feb 23, 2016 | 04:15 PM
  #214
Ive had the car since 2005. Been slammed since 06 with about 9 months in the middle of that being at stock height.
So roughly 10 years driving slammed and about 60k miles. Turns out the front bearings were ok, it was the rears that were making the noise. I changed the front ones out anyways, since i was already there and had the new units. Upon inspection of the rear bearings, the noise was being made by some rust in there...not sure how the rust got in there but the bearings were functioning just fine according to my mechanic.
Old Feb 26, 2016 | 01:02 PM
  #215
R2dMax's Avatar
WOW!! Only 60k in 10 years??Were the spacers on there the whole time? I put my wheels and spacers on (10mm f & 20mm r) on after I lowered it and got the fitment, but literally (and this could have been coincidental) within 500 miles got the rear bearing howl on both sides. It wasn't extreme either
Old Feb 26, 2016 | 02:59 PM
  #216
Haha yeah i didnt drive it much back then. No, the spacers were on it for only the last year. The bearing noise started a year or two ago but i just ignored it...it got worse and worse though. The total mileage was 174k before bearing replacement. 20 years and 174k...im pretty happy with the life of them.
Old Aug 8, 2016 | 06:23 PM
  #217
Nothing really new on the car except an issue i had where a long sleeve shirt got wrapped around my driveshaft, shredding my rear differential seal. Seal replaced, car still running strong. Just hit 180k miles. I finally found a reliable interior guy, so ill post some of his leather wrapping work on my car in the next few months. I contacted brabus to see if they would wrap my parts and their lack of response is not what i was hoping for.
Old Aug 9, 2016 | 09:48 AM
  #218
R2dMax's Avatar
Looking good!
As for Brabus, they must not remember how much effort you have put into this car... Customer service is dead
Old Nov 14, 2016 | 06:40 PM
  #219
Update on the car. One thing that always bothered me was my headlamps. I did a oem xenon upgrade a few years ago with two units that i got seperately on Ebay. Passenger side is from a 98 and drivers side is from a 96. For the life of me i have never been able to find a driver side xenon lamp that is as clear as my passenger side. It bothered me so bad that no matter how much i polished it or tried to restore it, it looked more yellow than the other side.
So i ended up purchasing a new set of OEM xenon headlamps from Hella. I figure its a good investment and will give me years of clear headlamps.
Crystal Clear!!!
Nice and clear, and even. I have other parts I need to paint and install...coming soon...stay tuned. Thanks for looking.
Old Nov 15, 2016 | 10:38 AM
  #220
illest's Avatar
w210 AMG or S213
looks great. I have the same issue. One of my lights is crystal clear and one is yellowed.
Old Nov 15, 2016 | 01:14 PM
  #221
@illest are they OEM xenons? If so I have a clear passenger side one.
Old Nov 15, 2016 | 04:43 PM
  #222
illest's Avatar
w210 AMG or S213
yes they are OEM, but I sold the car in my sig about a year ago and got a facelift e55 so unfortunately they wont work
Old Dec 21, 2016 | 06:56 PM
  #223
New parts update. Installed the facelifted mirrors today. I bought some silver ones from a board member and sprayed them myself. The paint match is pretty spot on so I'm happy with the way they turned out. Wired the signal to my front blinker.
Old Dec 23, 2016 | 01:27 PM
  #224
illest's Avatar
w210 AMG or S213
looks good.
Old Dec 29, 2016 | 11:37 AM
  #225
nelson09's Avatar
1999 E320
Old school! Glad to see you're still around and doing your thing!! Nice work since back then. I got rid of my 210 but am picking one up again in the near future it's reassuring to see I'm not the only one crazy about these cars!!!
