Spring Removal
-s-
Thanks,
rob lee
Here's a tip for the rear springs... remove the lower control arm bolt from the inside while the arm is supported by a jack. That's all you need to do. MB specifies that this bolt get replaced if it is removed.
For the front, removing the bolts is more difficult (as it is an A-arm), so you do need to remove the shock and the ball joint. A crowbar may be still necessary, but that's why I have the proper spring compressor. Takes about 10 minutes per side!
-s-
rob lee
