Need some basic help with E430
Does MB sell OEM shop service manuals?
What type of oil does this car take?
How do you jack up the car? Front or rear?
Any links to websites that would describe basic procedures for changing water pump, serpentine belt, etc...
Thanks!
option is to go online and pay by subscription for access time:
http://www.startekinfo.com/StarTek/
here is one nice group of semi technical information free which will give you
insight to the 210 design and operation.
http://www.mercedestechstore.com/w210.htm
here is another CD offering for about $10 but they're having manufacturing
bugs and the disks which have been sent out the past 4-6 months have not
been loading properly. I have a working copy and it is quite a fabulous gather
of tech sheets and data from MBUSA, drawn from the MB online service site.
https://mbworld.org/forums/e-class-w...ervice-cd.html
download owner's manual
http://www.mbusa.com/mercedes/servic...owners_manuals
here are some names from technical service bulletins for the 2001 E320 (I dont have for 430)
2001 Mercedes Benz E 320 4MATIC Sedan (210.082) V6-3.2L (112.941)
All Technical Service Bulletins
Number Date Title
S-07_61-039B 06/01/2005 Engine Controls - Adaptation Fault Code Diagnostics
2005020003 05/01/2005 Campaign - Harmonic Balancer Pulley Replacement
2005030005 05/01/2005 Campaign - Door Frame Corrosion
P-46_10-19 01/28/2005 Steering - Squeaking Noise Turning Steering Wheel
P-32_25-19 12/30/2004 Suspension - Shock/Strut Replacement Guidelins
P-82_10-419 12/30/2004 Lighting - Condensation in Headlamps
P-30_30-61 12/30/2004 Cruise Control Inoperative
P-67_30-12 12/30/2004 Body - Side Window(s) Open After One-Touch Closing
P-91_10-83 10/13/2004 Interior - Seat Cushion Rocks Makes Cracking Noises
P-27_00-47A 10/11/2004 A/T - 722.6 Oil Leaks From Electrical Connection
P-88_30-36 10/08/2004 Body - Scraping Noise From Transmission Tunnel Area
P-82_00-260A 08/25/2004 Audio System - CD's Won't Play or Eject
P-00_45-77 02/17/2004 Interior - Squeaking/Creaking Noise Kit
P-82_95-305 02/13/2004 Emergency Contact/Alarm System - System 'Runaway'
S-49_10-08 02/01/2004 Exhaust System - Rattling/Hissing/Humming Noises
S-01_30-15 02/01/2004 Engine - Cylinder Wall Damage Assesment
P-40_10-43 01/16/2004 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
P-18_00-20 12/05/2003 Engine - Oil Sludging Damage/Class Action Settlement
T-18_00-21 12/05/2003 Engine - Oil Sludging/Consumption Diagnosis & Repair
S-18_00-16A 12/01/2003 Gasoline Engine - Oil Sludging
P-83_40-68 10/20/2003 A/C - Unnecessary Blower Motor Replacement
P-82_60-292 09/29/2003 Audio System - Volume Knob Damaged
P-82_85-288 09/12/2003 COMAND(R) System - Unable to Enter New Destination
P-07_07-34 07/24/2003 Engine Controls - MIL ON/Multiple DTC's Set
P-82_85-264 07/22/2003 Navigation System - Inoperative/Erroneous Guidance
P-46_20-12 07/07/2003 Steering - Squeaking Noise
P-82_10-257 06/25/2003 Lighting - Headlamp Bulbs Inoperative
P-82_10-256 06/06/2003 Lighting - Condensation In Fog Lamps
P-20_10-23 05/07/2003 Cooling System - Water Pump Leakage
P-82_70-222 03/21/2003 Cell Phone - Phone Won't Fasten Into Cradle Holder
P-67_00-09 03/07/2003 Body - Windshield/Rear Glass Body Seam Corrosion
P-07_65-31 02/26/2003 Engine - High Oil Consumption
P-80_57-20 02/25/2003 Audio System - RF Interference Explanation
P-82_85-210 11/25/2002 Navigation/GPS System - Various Malfunctions
P-82_62-169B 10/28/2002 Audio System - Various CD Player Malfunctions
P-82_85-198 07/25/2002 COMAND(R) System - No Sound/Whistling
P-46_20-08A 05/29/2002 Power Steering - Horn Like Noises When Turning
P-47_10-16A 02/07/2002 Instruments - Fuel Gauge Inaccuracy
P-47_10-23 02/06/2002 Fuel System - MIL ON/DTC P03XX (Misfire)
P-82_60-161 01/30/2002 Audio System - Audio Voice Control Malfunctions
P-82_85-182 12/27/2001 COMAND(R) System - Various Malfunctions
P-80_30-13 11/01/2001 Smart Key(R) - Download Time
P-47_20-17 10/10/2001 Fuel System - Hard Start After Fuel Filter Replacement
P-40_10-33A 10/01/2001 Tires - Approved Winter/Summer Tires
P-82_85-171 09/13/2001 COMAND(R) System - Instrument Display Not Centered
P-82_85-170 09/13/2001 COMAND(R) System - Incorrect ETA Calculation Displayed
P-80_57-11 08/29/2001 Ignition System - Electronic Ignition Switch Replacement
P-07_65-14 08/21/2001 Engine Controls - Rough Idle After Coming to a Stop
P-18_40-14 08/17/2001 Engine Controls - Implausible Oil Level Messages
P-01_00-10 08/14/2001 Alternator - Mounting Bolt Identification/Application
P-91_60-48 08/09/2001 Air Bag System - Side Impact Sensor Replacement
P-47_30-15 08/08/2001 Emissions - OBD Shut-Off Valve Clicking Noises
2000100002 08/01/2001 Front Longitudinal Members - Subsequent Coating
P-82_85-152 08/01/2001 COMAND(R) System - Won't Respond to Voice Controls
P-40_10-37 06/01/2001 Wheels/Tires - Short Design Lug Bolts
P-54_10-053 05/01/2001 Battery - New `Fleece' Battery Technology
S-00_00-072 05/01/2001 Emission/VIN Label - Availability
S-05_010A 05/01/2001 Tools - Universal Valve Spring Tool
S-58_091A 05/01/2001 Special Tool - Universal Valve Spring Tool
S-58_20-93B 04/01/2001 Fender/Interior/Fascia Cover - Availability
200104001 04/01/2001 Recall - Replacement of Side Airbags
200104002 04/01/2001 Recall - Side Airbag Replacement
S-58_00-118 03/01/2001 Engine Oil - Approved Evacuation Equipment
S-40_10-036 02/01/2001 Tires - Maintenance & Inspection
S-00_40-071 02/01/2001 Synthetic Oil Recommendations - For FFS Vehicles
P-88_50-023 02/01/2001 Emergency Trunk Release - Retrofit
S-40_10-034 12/01/2000 Tires - High Performance Tire Storage
S-58_094A 12/01/2000 Chassis/Frame - Dedicated Frame Straightener
S-58_30-103A 12/01/2000 Special Tool - Resistance Spot Welder
S-58_30-115 12/01/2000 Special Tool - Resistance Welder
S-60_00-008A 12/01/2000 Special Tool - Spot Welder
S-60_00-012 12/01/2000 Special Tool - M20 Resistance Welder
S-60_004A 12/01/2000 Body/Frame - Dedicated Straightening Equipment
P-91_60-44 10/01/2000 Rear Door Airbag - Deactivation/Activation
P-40_10-033 09/01/2000 Tires/Snow Chains - Factory Approved Specifications
S-82_70-136 08/01/2000 Timeport Portable Telephone Programming
P-82_64-141 08/01/2000 Voice Activated Cell Phone/CD Changer Installation
P-82_64-135 08/01/2000 D2B Fiber Optic Configuration and Version Coding
2000100002 08/01/2000 Campaign - Body Sealer Application
DDAF42_10-U-6002A 07/07/2000 Selector Lever Blocks
DDAF82_60-U-6008B 07/07/2000 Radio Inoperative
DDAF97_10-U-4043FU 07/05/2000 Ingress of Water in Luggage Compartment
DDAF82_60-U-1105A 07/05/2000 Interference to Radio After Installing Window Screens
DDAF54_65-U-2000A 07/05/2000 PTS MIL ON For No Apparent Reason
DDAF91_00-U-3010Z 06/22/2000 Electrostatic Charge on Seats
DDAF42_45-U-8101B 06/22/2000 Electronic Stability Program Fault Code C1142
DDAF42_45-U-8103A 06/22/2000 ESP Fault Code C1120
DDAF82_10-U-2009B 06/22/2000 Main Beam/Low Beam Not Operating
DDAF54_21-U-6008A 06/22/2000 Operational Problem in Upper Control Panel
DDAH54_10-P-0001-01A 03/17/2000 Battery Safety Notes
DDAR54_18-P-0100-02A 03/17/2000 Repairing Wiring Harness Using Soldered Terminal
DDAF98_10-U-2005A 08/17/1999 Paint Damage to Trunk Lid in Area of Grip
DDAF42_45-U-8000A 02/11/1998 Steering Angle Sensor, DTCs C1140, C1504, 015, 016, 017
