What does it mean
Old Feb 14, 2013 | 05:07 AM
kniaz's Avatar
MB E320 W210 98Y
What does it mean
What does it mean SERVICE IN 30 DEYS
My Car W210 E320 98Y
Old Feb 14, 2013 | 05:44 AM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
It means you need to service your car/have it serviced in 30 days. Your service interval is up
Old Feb 14, 2013 | 06:14 AM
kniaz's Avatar
MB E320 W210 98Y
What specifically concerns?
Old Feb 14, 2013 | 10:07 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Your car's computer has a system called FSS or Flexible Service System. It monitors time and oil quality and determines when service is needed. There are two service schedules called A and B. Schedule B is more complex and they alternate. While an oil and filter change are part of each service there are several other items if done correctly. Your car came with Maintenance/Service Booklet. Same size as OM but much smaller(# pages). It lists the requirements for an A or B service. After the service is performed the FSS can be reset so it will begin the count down to the next service and eliminate the message you are seeing. That is described in the owners manual. If you are missing the docs they are available from a dealer. FYI - ebay sellers sometimes try to charge two times or more than the dealer for a used copy! MB has downloadable OM but not farther back than MY2000.
