2000 E430 4MATIC CD Changer in Trunk
Old Mar 3, 2013 | 12:38 PM
cjtucker's Avatar
2000 E430 4MATIC; 2006 Ford Escape Hybrid; 1992 300E 4MATIC; 1992 400E
The CD Changer for this vehicle is in the trunk. I do not know how it works or if it works. The car was a one owner vehicle, and frankly I do not even know if the owner did anything with the car. There is an auxillary wire in the slot under the radio deck. I confess, I have no idea how to work the cd changer. Does it come in and out of the trunk and hook into the wire?
When I select CD on the radio deck the message i get is "no cd".???
Any advice or points in the right direction. Thanks,
Old Mar 3, 2013 | 04:29 PM
01BlackE320's Avatar
01 E320
It stays where it is. You push a button on the top if the changer and a door slides open. There another button you push and the cartridge ejects. The cartridge has 6 little trays that open up each one holds a cd. put 1 or more cd's in the cartridge and pop it back in the player. You radio should now see and play the cd(s). Its possible that it wont work or that the prior owner abondened the changer in preference for the aux wire you mentioned. They were not the most reliable systems and trunk mounted changers were already dated technology even when these cars were built. My changer crapped out and I replaced my radio unit with a kenwood that has a single cd, bluetooth audio/phone and a USB connection. It uses the existing Boze amp and sounds better then the old unit ever did
Old Mar 3, 2013 | 05:50 PM
cjtucker's Avatar
thanks
I appreciate that. I'll give it a try.
