transmission fluid change
Old Mar 31, 2013 | 12:47 PM
blkmerc's Avatar
e430
does any one have a write up on how to do the filter and fluid change and how do i check the fluid level and how do i get the red cap of the transmission fluid fill hole ...i have a 2000 e430 sorry ita my first mercedes any info would help
Posted from Mbworld.org App for Android
Old Mar 31, 2013 | 05:46 PM
blkmerc's Avatar
e430
Originally Posted by Plutoe
Please don't tell me you want to change your fluid because your girlfriend thinks it's a good idea!!
no im a certified tech just not on mercedes im a ford tech but thanks for the smart *** remark i was asking for help
Old Mar 31, 2013 | 06:44 PM
raymond g-'s Avatar
99 E320
beside MBUSA's Startec servic, try reading up on these...
DIY #1
DIY #2
Old Mar 31, 2013 | 07:57 PM
blkmerc's Avatar
e430
The only reason I asked is because if you do a transmission fluid/filter change search you will find all the wrong reasons why folks change the fluid, therefore if you are changing for a reason and a tech you should be looking at the way the factory suggests with tools and measurements-----spend the 18 bucks an get a 24hr subscription to MB startec info put your VIN and search your transmission type for the quantity, type of fluid, tools and conditions to test fluid level----then go to e.bay and purchase a measuring tool---then go to MB EPC and locate the part number for the red cap, filter and gasket and order a couple from loads of places on the net or your local dealer. They are cheap!!
i just wana take care of the car it has 198846 miles on it and have no idea when it was done or if ever it shifts just fine and smooth but just for peace of mind
Old Mar 31, 2013 | 10:50 PM
saintz's Avatar
GL450
The tranny is a 722.6. Searching for that term will gets you tons of help.
Break the red tab with a screw driver or pliers. It is 1 time use. Then the black plug pulls out. Replace with new tab. You can get the tabs from the dealer or parts.com. You can get the filter from parts.com or autohausaz.com.
You don't have a drain plug on the torque converter. Don't sweat it. Change the fluid, run the car for a few minutes, change the fluid again. That will get most of it flushed.
Dip stick from ebay or Ohlord on this board.
Old Mar 31, 2013 | 10:57 PM
saintz's Avatar
GL450
You need Mercedes approved fluid. You can normally find Fuchs at autohausaz.com. Also there is Shell ATF that is Mercedes 236.14 approved which will work and is very cheap if you can find it. This stuff is normally used in Sprinter vans and Chrysler 5 speeds with the Mercedes transmission.
