2000 e430 running hot ?
Old Apr 7, 2013 | 03:12 PM
Johngoped's Avatar
1998 c43 amg
My 2000 e430 while at a stop light the temperature gauge will read a little under 100 degrees f is this normal ? Where do your guys w210 temperatures peak at ? Help and input will be greatly appreciated.
Old Apr 12, 2013 | 02:35 AM
track_warrior's Avatar
Like The Stig
Perfectly normal my 420 runs to around 100 and goes back down after the thermostat opens up. As long as it does not go over 100 you are good.
Old Apr 12, 2013 | 11:01 AM
toby1's Avatar
W210 2002 E320 CDi Avantgarde
Looks fine (and it's °C BTW)
Old Apr 13, 2013 | 01:08 AM
Johngoped's Avatar
1998 c43 amg
Thanks all you guys for the help I appreciate it
Old Apr 13, 2013 | 08:40 PM
Like The Stig
No prob man, glad we could help. If you ever see the gauge going over 100 i would start with a coolant flush and thermostat replacement. Im currently running Motul Mo-cool, its an additive you put in your coolant and helps keep the rad a bit cooler.
Old Apr 14, 2013 | 10:14 AM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
At idle, it's mostly your fan doing the cooling. Make sure your fan clutch (viscous coupling) hasn't bitten the dust like they do after about 120k miles.
