Replaced accumulators but my wagon still rides rough
I have now replaced the accumulators and sway bar links in the rear and the ride is still very harsh. I also can't get the self leveling system to rise with weight in the back. However, if I disconnect the lever from the sway bar and move it up the car will lift. Unfortunately, I didn't test it before I replaced the accumulators. I'm guessing that I need to adjust the linkage to the sway bar but any input is appreciated.
I replaced the tires with no change.
The real problem is the ride quality. I have taken a close look at all of the bushings and there doesn't seem to be any obvious wear that would explain my problem. Also, the rear subframe bushes do not appear to be cracked or torn even with the car on a lift and the wheels suspended.
This is a 1999 E320 Wagon with 146K.
Has anyone else had this problem?
