Oxidized headlight ,,what works
Old Feb 24, 2011 | 07:14 AM
stemags's Avatar
2014 E550 4matic,, sold 2012 E 350 4matic,,sold 2010 e350 4w,sold 2002 e320 se
Does anyone have an effective application for removing the dull film that covers older headlite lenses? My 9yr old needs something that will last.I know wd40 is a qik fix but with all the choices out there I thought I would ask the experts.
Old Feb 24, 2011 | 08:44 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
I got really good results with a polishing kit from a co. called Micro-Surface (www.micro-surface.com). They make two kits for acrylic headlights. I prefer the manual one. No risk of creating a flat spot as with a power buffer.
I did mine over two years ago now and they still look good. Took about a half an hour per side.
Old Feb 24, 2011 | 10:31 AM
saintz's Avatar
GL450
You can start soft and work your way up (least damaging) or just go to the big stuff (cheaper than trying multiple):
1) Meguiars Plast-X will remove light hazing from plastic
2) Mr Clean Magic Eraser with Plast-X on it will remove more
3) Headlight kit with sandpaper will remove more serious issues
3) Headlight kit with drill attachment
Kits are available from Meguiars, Mothers, 3M, and others. I would wax after you sand, because you are taking the protective layer off the light.
Old Feb 24, 2011 | 06:23 PM
stemags's Avatar
Thanks Richard and Saintz for the responses,,I actually do have some Scratch-X that I bought some time ago,,but Im going to look into the items you mentioned,,,not afraid of using a drill/buffer because I think its gonna take something like that to get them nice and clear.
Old Feb 24, 2011 | 06:37 PM
RichardM98's Avatar
This is what mine look like 2 years after doing them. Prior they were so cloudy and yellow you couldn't see any detail inside.
https://mbworld.org/forums/attachmen...eadlight01.jpg
Old Feb 24, 2011 | 08:31 PM
The Archman's Avatar
2011 C 300 2001 E 430
Mothers Headlight restoration kit has ingredients for 2 methods. First use the liquid and the drill applicator for the easy fix. Then it also contains 4 grades of sandpaper used with the liquid to really get the oxidiation off. You still need to repeat the process periodically since the original oxidation has broken that outside original seal. I am in the same boat, but I am thinking of replacing the headlights with HIDs. The original headlights on my E 430 are just the halogens, and with todays technology, I would like to get more light out of my headlights. I just haven't found a good source for HIDs that will give me 4000 to 6000 ( I don not want blue lights, but want good white diamonds)
Old Feb 24, 2011 | 11:02 PM
ohlord's Avatar
Follow
the diy on www.benzworld.org w210 diy section.
before and after
then toss in some 65watt rally H7 bulbs and go night driving
Attached Thumbnails Oxidized headlight ,,what works-dscf0104.jpg   Oxidized headlight ,,what works-dscf0101.jpg
Old Feb 25, 2011 | 04:32 PM
stemags's Avatar
Thats what Im lookin for Rich,,,I'd be thrilled to get em that nice...I looked into 3M and amazon is selling the whole thing for <$15 ....real reasonable I think. Meanwhile to Arch,,I dont blame you for wanting Xenons,,when the lense is clean they look good in 6000k,,,not too blue not too white
Old Mar 12, 2011 | 07:07 PM
stemags's Avatar
Wink
3 M restoration kit,,,$15 from amazon.com shipped with the pads and rubbing compound,,,thanks for the ideas and advice,,as usual this forum is terrific.
Attached Thumbnails Oxidized headlight ,,what works-1.jpg   Oxidized headlight ,,what works-2.jpg
Old Mar 12, 2011 | 10:52 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Those look great! Do you have any photos before you cleaned them up?
Old Mar 13, 2011 | 07:32 AM
stemags's Avatar
LOL nah,,,and its too bad too cause i got a new cybershot,,wunnerful camera.Thanks BTW ,,,I couldnt believe how well it worked.
Old Mar 22, 2011 | 05:40 AM
kanana's Avatar
E240
my car has a transmission slip had oil gear oil change it stopped on the road and had to be carried to my house. the abs indicator also keeps popping up after we changed the shock what would be the cause as the launch machine of today indicates code P2503 gear is implausible and impermissible transmission ratio
Old Mar 22, 2011 | 10:52 AM
RichardM98's Avatar
Try starting a new post since your topic is different.
Old Mar 23, 2011 | 07:19 PM
Ungarisch's Avatar
Tectitgrau S210
no magical potion required, just gradually sand with 800, 1500, 2500 sandpaper then wetsand with 3000.. works the best and last the longest, I tired every method, and my OEM Xenons look brand new..
they used look like the non-xenon fluted before because they were so foggy, now they looks like this:
Old Mar 29, 2011 | 02:58 PM
tikun's Avatar
1999 E 320 Sedan
Check out my business Partner Jason Chan. He specializes in Headlight Restoration for Luxury Vehicles.
http://windshieldwonderllc.com
Old Mar 30, 2011 | 08:21 PM
VARam1500's Avatar
2003 E500
My in-laws recently gave me an '03 E500. The lens covers were so bad that there were some places that they were pitted like rusting metal. There was a scale that had developed on the drivers side light. Although the plastic was still stuck on tight, it looked like there were clear corn flakes glued on the lenses.
I bought a Meguiars kit that came with a little bottle of Plastix, the buffing head, sealant, and two polishing pads (1000 and 3000 grit). I also bought a pack of assorted wet/dry paper. I had to start down at 320 to get the scale off, but progressing through 400, 600, 800, 1000, 2000, and 3000....then using the Plastix...I got great results. I wet sanded with all grades.
Old Apr 2, 2011 | 04:35 AM
91LTI's Avatar
W210 E320
I just had a go with Meguires PlastX..... needs another go, or something else...
Came up much better however... Though still faded compared to some of the pics above!!
BEFORE
AFTER
Old Apr 2, 2011 | 10:31 AM
Musikmann's Avatar
PlastX is a good product but only if there is very little oxidation. 91LTI, as you stated, you need something more aggressive.
Old Apr 2, 2011 | 05:16 PM
stemags's Avatar
Yes that needs some cutting with abrasives,,the 3M system took 1 hr per side.Very impressed with it.
Old Feb 11, 2013 | 12:54 PM
ravennexus's Avatar
e430 avantgarde
sorry for bringing up an old thread. only had my W210 3 weeks.
this is 2min a side with autosol metal polish by hand, not bad for a quick blast, need to do a bit of drill mopping with it to get them perfect.
Old Feb 11, 2013 | 06:04 PM
siopaolover's Avatar
1998 E320
looks good
Old Feb 12, 2013 | 06:55 PM
Doolittle's Avatar
2002 E320
+1 on the 3M product. I cleaned my headlights this past weekend and and very pleased with the results.
Old Feb 12, 2013 | 11:48 PM
a_gulbs's Avatar
E-320
this is going to sound really random but i got the idea from mighty car mods. if you use the outside skin of an avocado and buff your headlight with it, it eliminates the film and restores your headlight. it actually works ive tried it
Old Feb 21, 2013 | 06:09 PM
pod210's Avatar
1998 E320 (W210)
Polishing is a losing battle - best to just replace the lenses if there is heavy oxidation.
Old Feb 22, 2013 | 12:44 PM
PolarGlade's Avatar
1996 E320
Listen to Ungarisch on this. I have used the wet sand paper method on six different cars. Including the E320. It is cheap and gets the results you are looking for. Any true hardware store will have at least the 1500 and 2000 grit. They go from yelllow to showroom. I did use the plast-x for the final polish.
Just keep your paper wet and do it by hand. Nothing like doing it right and seeing these kind of results.
