Clunking noise after installing Bilstein Sports
Old May 2, 2013 | 01:59 PM
siopaolover's Avatar
1998 E320
I finally got around to putting in my rear Bilstein sports yesterday. It handles great! But every time I go over any bumps in the road, there's a clunking coming from the rear passenger side. The drivers side doesn't make the same sound, so I'm stuck wondering what it could be. Any suggestions/experience with this problem?
Old May 2, 2013 | 08:40 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
Did you remember to put the dust covers on this time? :p
Old May 2, 2013 | 11:54 PM
raymond g-'s Avatar
99 E320
did you torque them down to the recommended tensions? does the left torque
tensions match the right side? we can't tell you over the keyboard as much as
you can if you just backtrack and proof your work. start all over if needed.
Old May 2, 2013 | 11:58 PM
SerbNerd's Avatar
2001 E430, 2002 ML55
Check your sway bar (bushing?)...I finally did my lower ball joints up front and now I hear the sway bar clunking. Worth a check.
BTW: #3226 in the PDF
Old May 3, 2013 | 06:42 PM
mufc's Avatar
2006 CLS55
Check the top mounting, it is either loose or the rubber bushings are worn ( squashed ) too thin. I use battery impact wrench to tighten these nuts, much faster than holding the top of the shock pin with with a special shock wrench to stop the shaft rotating while tightening the 17mm nut/nuts.
Old May 11, 2013 | 10:23 AM
admiral brows's Avatar
e430 4matic
could have broken a latial link in the rear. most of the time when people take them off there broken
Old May 12, 2013 | 12:04 AM
1998 E320
hey guys, sorry for taking long to post. I've been caught up with school and work, so I'll be sure to get under there this week and report back. thanks for all the advice
