Transmission Issue - 1997 E420 Sport - Help!
Old May 5, 2013 | 01:24 PM
eric.w.striblin's Avatar
1997 E420
Exclamation Transmission Issue - 1997 E420 Sport - Help!
Driving down the interstate this weekend on cruise control I raised the cruise lever to increase the speed a bit and suddenly the revs shot up and the transmission appeared to slip into neutral as you could feel the engine rev but the power was not reaching the wheels.
Pulled over and let the car sit for a few minutes and started it back up and this would let me drive a bit further until it would slip back into neutral again. I am getting a "check engine electronics" light on the display and you can hear a bit of a belt/fan noise coming from the left side of the engine in the brief moments it was drivable after the issue occurred.
Managed to get the car home after a lot of pulling over, let it sit, go for a bit routine but am at a loss for what to check and am trying to track down a local mechanic that handles MB work as the closest dealership is about an hour drive from here. I've read a bit about the "limp home mode" and I don't believe it is being forced into this as during the moments that the power does reach the wheel it doesn't appear to be limited to certain gears. Any suggestions/input would be greatly appreciated!
