SRS Occupancy Sensor Replacement
Old Jun 7, 2013 | 10:39 AM
JiatTi's Avatar
w210 e200, w220 s280
Question SRS Occupancy Sensor Replacement
Any Steps, instruction or tips for replace the occupancy sensor under the seat?
Old Jun 7, 2013 | 08:55 PM
JiatTi's Avatar
OK, Thanks for your reply
Old Jun 8, 2013 | 05:06 AM
raymond g-'s Avatar
99 E320
this will give some insight into the degree of difficulty
Old Jun 8, 2013 | 11:01 PM
J spaulding's Avatar
1999 MB E430 1998 SL500
The problem is quite likely the
wires coming from the seat sensor instead of the sensor itself. If you play around with the wire bundle it will probably fix itself.....for free. They short out on the seat frame.
Old Jun 9, 2013 | 07:24 AM
renault12ts's Avatar
W215 CL500 2005
The cable passes through a sharp hole in the base of the seat...this cuts the wire. I didn't try to fix mine...there wasn't much room...but if you did some dismantling of the seat you could more than likely solder the broken wire.
I fitted an emulator...so the SRS is always active.
Old Jun 10, 2013 | 06:18 PM
EdzBenz's Avatar
W210 W140
Reneault,
How did you fit an emulator? Could you give us some guidance? I would like to do this on my car. Thanks for any help.
