Help with OBD readers
Old Jun 24, 2013 | 06:42 AM
cheezels's Avatar
1999 E55 AMG
OK, I've posted a few times asking questions about obd readers, but I'm still a bit confused.
I don't have an OBD2 port. I have the 38 pin socket under the bonnet.
Does anyone know if the 38 pin socket is OBD2 compatible?
I'm looking at the 38 pin to OBD2 conversion cables available on ebay. Then buying a generic code reader.
Will this work?
I'm all confused
Old Jun 24, 2013 | 10:29 AM
raymond g-'s Avatar
99 E320
i dont think that Euro marketed cars were required to have OBDII compliant ports until 2001.
i also dont know where AUS ranked in terms of this requirement (mandatory year). so it is
possible that your car really doesn't have it at all.
Old Jun 24, 2013 | 01:36 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Yes the OBD codes are available on the 38pin connector used by the MB SDS. I would definitely look for a complete system (adapter cable/reader). Buying bits and pieces off eBay may or may not work.
Old Jun 24, 2013 | 05:51 PM
cheezels's Avatar
1999 E55 AMG
Ok, just to be clear.
I do not have the obd port under the steering column.
I only have the 38 pin connector under the bonnet
I believe this is obd1.
So, is an obd2 reader able to work with this port?
Or do I need to get something else.
Old Jun 24, 2013 | 07:05 PM
cheezels's Avatar
1999 E55 AMG
Ok, thanks for that.
So obviously an obd2 reader (with an adaptor cable) will not work.
I think I read somewhere this is a can port.
Old Jun 24, 2013 | 07:54 PM
cheezels's Avatar
1999 E55 AMG
Not sure what you're on about.
I'm just trying to work out what I need to read faults.
Think I'm there now
Old Jun 24, 2013 | 07:57 PM
cheezels's Avatar
1999 E55 AMG
Just noticed you sign off with
Love my das xentry
Care to share your thoughts/ experiences etc
Cheers
