ABS, ESP, BAS problem + gearbox doesn´t shift
Old Jul 12, 2013 | 07:45 PM
MichalMazák's Avatar
E240 W210
Hi guys,
I have special problem with my W210 E240. I was reading many forums with ABS, ESP, BAS problem but I couldnt find exactly same problems what I have. After start the engine allways after about 3 minutes (when I turn off ESP it is about 10 minutes) speedometer stops working and in one second later , board computer shows ABS, ESP, BAS problem and gear is stucked and I have to drive only on one gear. It is difficult to accelerate on fourth or fifth gear and fuel consumption is enormous than. SRS and engine light is on as well. Brake lights works good, just one bulb is broken and brake light switch is replaced. Fuses are allright. Problem will be maybe in low battery voltage because before I bought that car it wasnt used for 6 months and cold engine starts hardly. Thank you for your opinions.
Old Jul 15, 2013 | 04:23 PM
E240 W210
I fully charged that battery but nothing has changed. Do you think that is not real reason of all problems or these malfunctions must be deleted by computer in the service? thank you
Old Jul 18, 2013 | 06:01 PM
E240 W210
I m ordered in service to next week so I will spend some and make it done. I m just trying to find out the reasons why is not working and know more my car so I don´t think that is time wasting. Easiest think is go to the service and spend lots of money but sometimes when you know that car better you can buy things for yourself and make it done by yourself(I m not saying that allways but sometimes yes). And service is not about saving money and finding cheapest way how to fix it but about making great bills , if bigger than better..You want benz? pay!
I was trying to find out what else could it be and I found under the rear seats turn rate sensor which is very noisy so I m not sure if it works O.K so it can be problem too. What you think? many thanks
