Charged A/c still won't blow cold
2001 e320 wagon
First let me apologize if I am repeating a thread... the last thing I want to do is annoy the super helpful people on this site. I did search but could not find the same problem.
Problem/history: At the end of last season, my A/C was blowing just barely below room temperature, but still cooling. I added 134a, but noticed it was leaking at the valve. Did nothing else until this spring when I replaced the valve and cap ($30 - of course MB puts the Shrader valve in a proprietary housing). When I swapped the valve, I worked fast such that I stopped the hissing of escaping refrigerant by the tightening of the new housing--the idea being that if there is still pressure in the system forcing refrigerant out, then atmosphere (with its pesky humidity/moisture) could not yet enter the system. I recharged the system to the CORRECT pressure. The system now works as designed on AUTO, but the air blown is not cooled. Compressor is engaging.
Any experience on this one?
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
You make big mistake-----simply do the fault test and the actual value test(see stickies)----post the data and you will get help---without the tests the replies will be ----forget the test just add more refrigerant or who understands the test any way, just add more refrigerant----bla bla bla
1997 E420
You may have avoided allowing the air to enter the system but 134a is a blend of a few chemicals that boil/evaporate at different pressures, even quickly venting them to change a schrader type valve will most defiantly cause an imbalance in the refrigerant's mix ratio. find a buddy with an A/C vacuum pump to assure a complete evacuation, then you can recharge with the proper amount.
This is the reason they recommend we add the compound in a liquid form instead of a vapor like r-12, it did not separate and was easy to just top it off a bit.
Although some of there stuff is pure crap, Harbor freight has a inexpensive set of automotive 134a manifold gauges, and a cheep little single stage vacuum pump, have used mine successfully for over 4 years now. But just for myself and friends. Without any issues.
If your compressor is operating it is a must to have a correct charge. or compressor failure will occur.
You might have a stuck damper, vacuum issue?
Can you use the selector arrows and make the air discharge differently,
floor, defrost, vent etc.
hope this helps a little
Everyone has an opinion, lets find the solution
