Flash to pass
Old Jul 20, 2013 | 08:23 PM
Rich's 97 E420's Avatar
1997 E420
Flash to pass
I have a question my high beam-low beam selector works just fine but my flash to pass wont do anything? is there a separate relay involved. kinda weird?
Old Jul 22, 2013 | 05:11 PM
1997 E420
Yup it has HID's. Guess we will just have to use it as is. Thanks
Old Jul 22, 2013 | 06:13 PM
renault12ts's Avatar
W215 CL500 2005
Did your car have HIDs as standard?
If yes, then you should have the flash option..I do on my car with HIDs. It's the smaller inner (halogen) lamps, the main beams, which do the flashing.
Old Jul 22, 2013 | 07:50 PM
1997 E420
Here are a few pictures, the 2nd parking lights, 3rd low, then last the high beams, found it unusual the high beam lamp is located in the marker light housing, The PO installed the lights stated they would never need to be replaced? Also stated the headlamps ($1000) and rims ($5000) cost more than I paid for the car?
So is there a soloution to get the flash to pass feature back?
Plutoe: To use the feature just pull back, release, pull back the stalk a couple of times------if that does not work your switch is most likely bad.
Old Jul 22, 2013 | 07:51 PM
1997 E420
Are there any downloadable PDF's for wiring schematics on Das Auto's
97 E420
Old Jul 22, 2013 | 07:53 PM
1997 E420
Pictures
Attached Thumbnails Flash to pass-hls4.jpg   Flash to pass-hls1.jpg   Flash to pass-hls2.jpg   Flash to pass-hls3.jpg
Old Jul 23, 2013 | 09:11 AM
W215 CL500 2005
That's correct...the high beam is in the marker (smaller) housing.
Old Jul 23, 2013 | 07:58 PM
1997 E420
So what do you think might the selector switch be bad?
Old Jul 23, 2013 | 09:47 PM
1997 E420
<!-- google_ad_section_end -->
Gosh! I sure hope my switch hasn't gone bad. lol
Sorry plu the reason I don't really take your answers seriously. It is mostly because your usually a douche when you answer a question with overwhelming amounts of sarcasm.
But on the other-hand I think your very intelligent individual and have seen some very helpful reply's from some of your posts?
Any ways do you have an electrical schematic for my vehicle so you can be helpful?
