E430 rich cold start
Old Aug 14, 2013 | 10:53 PM
J spaulding's Avatar
1999 MB E430 1998 SL500
Does a 1999 E430 have a separate cold start system such as an extra injector or is the cold start built into the ECU? I am getting dark smoke out of it for 2 seconds on cold startup.
Old Aug 15, 2013 | 12:47 AM
MOTOJAE's Avatar
2002 CLK55
Sounds like valve guide seals are leaking...no xtra injectors..if you have an issue with the mass air flow sensor it should trigger the check engine light.
Old Aug 30, 2013 | 12:31 AM
ohlord's Avatar
Secondary air injection has nothing at all to do with the intake and air/fuel ratio.
It injects air into the exhaust to heat the cats faster upon cold start.
Where you come up that it will richen anything must come from the same place all the other **** poor off the wall info you spread.
Why waste time saying if he has a 112 or 113 engine? He says he has an E430 thus it is a 113, or don't you know that?
I forgot, Nope you don't know that.
