99 E320 Transmission Service
Old Aug 26, 2013 | 05:28 PM
khansab1's Avatar
1999 E320
Hi, I have a 1999 E320 with 190k miles on it. I want to change transmission fluid because it is black and smells burnt. Car is running okay though. Transmission shop guy said don't change. It might not work after new clean oil. I am confused now. What should I do??
Old Aug 26, 2013 | 06:10 PM
LVGBENZ1356's Avatar
99 E320 W210
Change it. My e320 had 225000 miles when I changed the trans filter and the fluid in the pan. I wasn't sure either because I heard the same that it wouldn't work. Start with changing the filter and fluid. I wouldn't recommend changing the fluid in the torque converter. Slowly refresh the fluid. I recently did this service myself , pretty easy got about 4 liters out.
Old Aug 26, 2013 | 06:59 PM
khansab1's Avatar
1999 E320
Thnx <!-- google_ad_section_start(weight=ignore) -->LVGBENZ1356<!-- google_ad_section_end -->
I will go ahead and change it.
