Headlamp assembly replacement 2001 E320
Old Aug 26, 2013 | 07:36 PM
hdholdingsinc's Avatar
Mercedes 2001 E320 Sedan
Hello! I have a 2001 E320 Sedan that requires a new headlamp assembly on the driver-side. I have been told that to do this the front bumper must be removed to get the assembly out and have been quoted $600 for the parts and labor. I believe I can obtain the parts for around $175. Have any of you accomplished this? Any tips or special tools required? I did see a short video featuring a 2005 E320 and it did not require removing the bumper... just the bottom mounting panel below the headlamp assembly. Any info will be greatly appreciated!
Old Aug 27, 2013 | 01:17 PM
renault12ts's Avatar
W215 CL500 2005
You have a W210...why would you think a W211 is the same in any way?
You must remove the bumper. Then it's straight forward.
https://mbworld.org/forums/w210-amg/...mper-w210.html
