W210 Issues! HELP!!
Old Aug 30, 2013 | 03:14 PM
spdhntr's Avatar
95 W210 E320
Exclamation W210 Issues! HELP!!
Hey there,
recently my w210 e320 started giving me some problems all of a sudden.
1. when i rev it high on low gears (5000 rpm or above), the engine looses its smoothness after coming back to standstill. the car shakes, it looses power, just dosent seem right
2. my SRS light stays for exactly 90 seconds whenever i turn the car on. it disappears after that, never comes back while its running.
3. climate control shows temperatures that are 30+ the actual temperature!
4. i hear a rattle sound from under the car at low revs and some specific revs 3000 rpm-ish
Any help/advice/experience would be appreciated, cheers.
Old Aug 30, 2013 | 08:44 PM
Figuero's Avatar
2002 E430 4MATIC
Originally Posted by spdhntr
Hey there,
3. Climate control does not show the actual temperature. It shows the set point.
4. Sounds like the dead cat rattle.
Old Aug 31, 2013 | 12:02 AM
spdhntr's Avatar
95 W210 E320
oh sorry for the third one its not the climate control its the temperature gauge, which shows the outside temperature, the one located on the instrument cluster. too freaked out hence typed in climate control i guess.
Old Aug 31, 2013 | 09:52 AM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
External temp sensor is located under front license plate area in lower front bumper.
Old Aug 31, 2013 | 10:49 PM
spdhntr's Avatar
95 W210 E320
sweet got that bit sorted. my car was built in Germany, so by the gear selector i have a switch that toggles between drive modes and says "E" or "S" instead of the usual "W" or "S". Does anyone know which one i am supposed to use for daily non snowy conditions?
Old Sep 1, 2013 | 06:50 PM
illest's Avatar
w210 AMG or S213
1. When was the last time you changed you spark plugs, air filter, maf? Does the same thing happen if you rev in neutral?
