My left side Stereo sound goes out!
Old Sep 10, 2003 | 11:01 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
On infrequent occasion my complete left side sound goes out while using CD I believe. I check the balance and fader controls and they are correct. I turn the unit on and off and no correction. It returns to normal only after restart.
This is one of those problems that when you take to the dealer it is working fine and they will have the car a day or two and state they can not duplicate the problem.
How Many amps does car have? Is there a separate amp for left and right? Thanks.
Old Sep 10, 2003 | 11:18 AM
pakman's Avatar
98 e430sport
Hi E55,
This sounds similar to the problem I was having with
my 2000 E320 when I was in Germany. I had the BOSE
and COMAND options. It usually would happen when
the stereo was set very loud and some other things
happened (e.g. phone rings, ignition off, etc). Sounded
to me like it was a SW issue since it seemed to reset
itself after turning off the car, taking the key out, locking
unlocking the car.
I had the dealer update the SW version in the COMAND
unit and that fixed it. They had to order a new EPROM(?)
from Mercedes for it (or so they said).
Old Sep 10, 2003 | 12:42 PM
Benz's Avatar
2000 F-150 XLT Sport Crew Cab
You have 1 little cheap crappy AMP....We all do in our cars....It sucks how bad it is I am on the same boat with you not Kev...My car is doing the SAMETHING as yours is right now....I just checked mine out and it's blown hehe...Yours may or may not be blown...Could be the wiring im not sure....but a peice in my rear speaker broke so now im buying new speakers for the inside.....I have no idea what im going to buy but it has to be cheap
Old Sep 10, 2003 | 01:43 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Remove the left trunk lining and check for signs of water incursion around the amplifier... the body shell is prone to leakage in that area and it can cause all kinds of problems with the amplifier. While you're in there, make sure the drain tube is properly routed; also make sure the drain holes in the well (where the CD changer sits) are not plugged.
-s-
Old Sep 10, 2003 | 03:40 PM
Benz's Avatar
-s-
whoa scorchie...I never knew you were part of this board....I sold you the steering wheel on ebay....I was the long lost shipper hehe....Never knew you came here...Nice to see you around here.
Old Sep 10, 2003 | 05:09 PM
E55 KEV's Avatar
Veteran: Air Force
scorchie is always helpful!
