ABS and ETS warning light
Old Mar 8, 2002 | 12:52 PM
007's Avatar
007
Unhappy ABS and ETS warning light
hey guys,
got a warning light on the ABS and ETS while driving yesterdayon my 320. anyway i have service appointment next week, but just wanted your opinion on what the possibilities of what the problem(s) is and extent of work needed so that i can schedule how long i need to get off from work for. thanks
Old Mar 8, 2002 | 02:02 PM
55LOVER's Avatar
The same thing happened to my ML55. Is it a ML320 or other. Here is what the dealer told me. First of all I took it to the dealer every week for about a month. They had no idea what the problem was. Finally they came up with that it has to do with the sensors and steering. I never got a straight answer but they did finally fixed it. Send it to the dealer and you should be fine.
Old Mar 9, 2002 | 09:12 AM
svc's Avatar
svc
Mercedes-Benz A190 (W168) and E220CDI (W210)
The same happened to my E220. My problem was a black mud in the front left wheel ABS sensor. A strong water spray in this area fixed that issue. I realize it works magnetically, but maybe some iron powder was mixed in the mud...
Old Mar 9, 2002 | 08:24 PM
barflux's Avatar
CLK 320 Avantgarde
They may have to replace the esp or asr switch
the esp and bas light came on, and it was due to faulty switch, happened alot to clks
Old Mar 11, 2002 | 10:42 AM
ryson's Avatar
2014 E350, 2008 C300 Sport
ABS ETS lights
Same thing happened on my '00 E320. It's just a faulty relay switch. Easy fix at dealership and covered under warranty.
Old Mar 13, 2002 | 01:21 PM
007's Avatar
007
just an update for u guys,
thanks for all your suggestions. anyway i brought the car to the mechanic, it turned out to be brake switch that was broken. got it fixed for 35 dollars for parts.
however, it took them a while for diagnostics.
