98 E320-Where's the CD Changer cable?
Old Sep 13, 2003 | 12:47 PM
TRSMBE320's Avatar
Question 98 E320-Where's the CD Changer cable?
I bought a USA Spec 6 Disc CD Changer for my 98 E320. It came with an adapter that apparently just plugs into the cable in the trunk with no splicing necessary.
I was told the cable would be behind the carpet in the right (I assume right means passenger side here in the US?) rear quarter panel in the trunk. I removed the carpet from the right rear quarter panel but I can't find the cable!
Also, where's the best place to mount the changer?
Thanks for your help.
TR.
Old Sep 13, 2003 | 01:07 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: 98 E320-Where's the CD Changer cable?
TR.
You couldn't find the cable because... you were told the wrong side! It's behind the LEFT side. Try doing a search here in the forums and you should find this information already.
-s-
Old Sep 13, 2003 | 06:48 PM
TRSMBE320's Avatar
Re: Re: 98 E320-Where's the CD Changer cable?
-s-
Thanks - found it! I installed it under the parcel shelf on the drivers side. It was REALLY simple once I found the cable and literally plug and play! Works directly off the factory installed radio too - no RF remote controllers.
Thanks again for your help.
TR
