Fiber Optic hook up.
Old Oct 14, 2013 | 08:19 PM
CHolmes's Avatar
2000 E320
I know it must be in here somewhere but I have searched and cant find it. 2000 320 wagon, it came with the phone and no changer, I had a changer so I installed and used the cable from the phone, works great but I would like to hook the phone back up to (works for 911) do I need another cable? I don't see an "output" on either PH or CD. How does that work to have both? Is there a cable with two ends?
Old Oct 14, 2013 | 09:13 PM
raymond g-'s Avatar
99 E320
dunno if this helps. i found it in a folder of misc MB w210 stuff. will leave the heavy reading to you.
File Type: pdf
Old Oct 16, 2013 | 01:09 PM
CHolmes's Avatar
2000 E320
Yup, lots of reading there. Doesn't address if there is a CD player in the loop, only phone.
Old Oct 20, 2013 | 10:54 PM
raymond g-'s Avatar
99 E320
the fiber circuit must operate in a loop so if I'm picturing this properly, you're
running with phone, head unit, and changer. so each of the 3 components
must tie in to two others: head unit must be connected to changer and phone.
phone to changer and head unit. changer to phone and head unit.....all via D2b
fiber compliant cable
Old Oct 21, 2013 | 06:18 AM
CHolmes's Avatar
2000 E320
Yes, I already know all that. Question is how? do I need another cable/two? Y connector?
