Signs of leaks under the intake manifold
Old Oct 18, 2013 | 07:01 PM
MitchTX's Avatar
2002 C320
On my 98 E300D I can see signs of either previous leaks or existing leaks on components under the intake manifold. It is hard to see under there, so I'm thinking that maybe I need to remove the manifold, clean up the various components, re-install manifold, and then watch/monitor.
I've never done this before but have read the DIY article about replacing the glow plugs over at peachparts and it looks simple enough to remove/replace the manifold.
Must I replace the gasket every time I remove the manifold? If I do it the first time, then find leaks, and pull it again with 2 weeks or 1000 miles to fix the leaks would the new gasket be new enough?
