Crank position sensor/coolant temp sensor codes
Old Nov 3, 2013 | 05:46 PM
midnightsaint's Avatar
2001 E320 4matic Estate
My car kicked both codes today. It runs great I cleared the codes. But the cel came right back on. I am thinking it has to be a common ground issue maybe. Anyone have any ideas before I call the shop tomorrow?
Old Nov 3, 2013 | 07:23 PM
So where is the fault?
Old Nov 3, 2013 | 08:06 PM
Ok **** face. I know the codes I know that both sensors don't just go out at the same time. I'm not going to replace both sensors when I know that not the real issue. I do not know the real issue. I forgot that this forum does nothing but ***** and moan and talk ****. I will find a better place to ask my questions. Mods delete this post and my account. I'm done here.
Old Nov 6, 2013 | 08:06 PM
btw my ecu had to be re flashed. For some reason every control module in the car showed a fault. We checked the k40 and it is fine. Re flash and all is good.
Old Nov 6, 2013 | 10:10 PM
raymond g-'s Avatar
99 E320
i'm curious. was this an OE flash by an MB dealer or do you have an aftermarket ECU chip?
Old Nov 8, 2013 | 01:33 PM
OE flash.
