code reader
Old Nov 3, 2013 | 07:31 PM
Skyline 123's Avatar
E320 4matic
code reader
Can I plug my obd2 code reader into my E 320 4 m 2002 sedan? thanx and where is the outlet
Old Nov 4, 2013 | 05:26 AM
JonasDikkanen's Avatar
2000 E220 CDI Sedan
There should be an outlet under the steering wheel, if you indeed have one. I have a 2000 E220 CDi which don't have one, as the OBD2 became a standard a couple of years later on the diesels, here in Europe at least.
Old Nov 4, 2013 | 12:39 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
OBD connector is just to the right of the hood release. There is a hinged plastic cover to release. OBD II was standard in US with 1996 - later vehicles.
Old Nov 4, 2013 | 05:38 PM
E320 4matic
Thanx guys that will help I now have an intermitted abs and bac light comes on every few days but sometimes I drive 500 miles no light how do you reset the warning system and what do you guys think what is causing it ?
thanx once again
Old Nov 6, 2013 | 03:35 AM
2000 E220 CDI Sedan
I don't know, I had the same recurring problem last year, but went away every time I restarted the car, and haven't seen the lights since then.
Old Nov 9, 2013 | 06:49 PM
E320 4matic
Originally Posted by Plutoe
As you have learned the ABS is not emissions related therefore your obd reader can not read the codes, clear the faults and bla bla.
Find an indy with factory software.
Well I am new to the world MB diagnostics What is an Indy and where do I get it and the factory software. Thanx Big Herb
Old Nov 10, 2013 | 11:58 PM
ohlord's Avatar
I would suggest
To come up to speed, I would suggest ,every time you can't define or understand Plutoe, Google A****le and you will find an apt definition.
In regard to your warning lights check your batteries charge (should have a full 12.8 volts) clean the battery terminals and replace your brake switch.$15 and 15 minutes and problem solved.
Old Nov 11, 2013 | 03:57 PM
E320 4matic
Thanks for your advice and I am with you on the first sentence
