help gearbox problem
Old Dec 14, 2013 | 05:50 AM
bmjoaquim's Avatar
mercedes e220 cdi w210
Unhappy help gearbox problem
Come use your help, I have a W210 e220CDI 2001 with automatic transmission changed the electronic board, oil filter, put new oil until the entire circuit to clean the old oil did all the maintenance box because so entered safety box was in neutral.
I noticed some difference changes better come good, but when the car is inclined to make the kickdown change rather than the change does not get any engrana, this happens mostly when the car is tilted, but not always, or when I make a quicker acceleration this situation has happened before servicing.
Errors that gives the machine are as follows; Autotransmisson P2500 and P220A and EZS B1156.
Thanks in advance for your help and I have to do to get this resolved
Old Dec 14, 2013 | 10:48 AM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
Recheck fluid level. Should be at the max mark when fluid temperature is 80C.
Old Dec 14, 2013 | 02:52 PM
bmjoaquim's Avatar
Unhappy Help gear box problem please
I checked the fluid level and the level is
Thanks for the help
Old Dec 14, 2013 | 05:45 PM
bmjoaquim's Avatar
Unhappy help gearbox problem please
thanks for the review.
What causes me some strangeness is that the fault only happens with inclined or is curved or uphill acceleration when the car is faster.
Thanks all for the opinions, however I'm waiting for more reviews
