Both rear breaks stuck on?
Old Dec 23, 2013 | 02:43 AM
Jwoods2112's Avatar
1998 E320 4matic
So I was experiencing more than the usual turbulence on the interstate today. Both rear breaks were stuck on, not locking up rear wheels but dragging big time. I stopped and could hardly touch the drivers side rear wheel it was so hot, and the passenger was quite hot as well. What could cause both calipers to hang up like that? Bad master cylinder? Thanks for any intel
Old Dec 23, 2013 | 08:05 AM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
Are you sure it's the calipers and not the parking brake shoes?
Old Dec 23, 2013 | 10:52 AM
Fabio D's Avatar
210 55
We have one car in the shop with this symptom, the problem is a Cloged abs/esp actuator. we found a used one, replace it and solve the problem. this faulty in the abs unit is caused by a non brake fluid flush. Take care you need to replace brake fluid every year.
But same here, you sure is not the parking brake stuck first?
Fabio Daniel
Old Dec 23, 2013 | 11:06 AM
Jwoods2112's Avatar
1998 E320 4matic
No I'm not sure of anything, I was suspecting something like Fabio stated, but embrake could be it as well. The symptom can completely disappear so does that rule one of these out?
Old Dec 23, 2013 | 11:23 AM
Jwoods2112's Avatar
1998 E320 4matic
When it happened last time (a year ago) I couldn't budge one of the caliper pistons (left rear) until something decided to just let off, I think this points to a hydraulic problem-- most likely that actuator Fabio mentioned right?
Old Dec 23, 2013 | 12:38 PM
Jwoods2112's Avatar
1998 E320 4matic
sorry i'm anxious to fix this obviously, its one of the family transporters. anyway, if i want to begin trying to find the actuator you spoke of Fabio--am i looking for the "abs pump with esp" or how do I find that part, would you happen to have a part #? thanks
Old Dec 23, 2013 | 05:16 PM
Jwoods2112's Avatar
1998 E320 4matic
Agreed
Old Dec 23, 2013 | 09:47 PM
Fabio D's Avatar
210 55
Yes, i'm talking about the abs pump, we replace several unit clogued by a non brake fluid flush. I think like yours, is an hydraulic issue and not electronic issue, is pretty common in the w202 this problem too friend! let us know what you find
Fabio Daniel
Old Dec 27, 2013 | 06:46 PM
Jwoods2112's Avatar
1998 E320 4matic
Well to let you guys know how it all shook out--it is as Fabio suggested, the abs pump/valve assembly, I paid $265 for that information!
So I guess I need a bargain unit to throw in there, it's an "ASR" unit, let me know if you've got any good sources.
I will try my luck with ebay units until then, cheers and thanks for the help Fabio!
Old Dec 30, 2013 | 06:33 PM
Fabio D's Avatar
210 55
Your welcome friend, buy a used unit at ebay. (take care this cars comes with 2 versions ASR/ABS and ESP/ABS) do a brake flush all the years.
Fabio Daniel
