please someone help lol
Old Jan 19, 2014 | 11:57 AM
trouble0214's Avatar
1999 e320
hi well this is my problem i just picked up a 1999 e320 for 1900$ looks brand new got it from an older lady in fl the only thing wrong with it is the power windows seats and locks wont work but if i unplug the batt for 10 min it works again for a day or 2 then stops and i have to disconnect the batt again does any one know what is causing this or had the same problem any help would be great i am sure this has been asked b4 on here but i am new to the forum and could not find it
Old Jan 19, 2014 | 01:05 PM
Prfxnst's Avatar
MB 2001 E430, 2006 SL55, Yukon Denali XL
Try synchronizing feature. Should be in owners manual.
Old Jan 19, 2014 | 01:07 PM
1999 e320
Did not have the manual in the car do u. Know what it is or if anyone posted the procedure on here and thank you
Old Jan 19, 2014 | 01:29 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Not your problem. Resyncing applies to windows (express feature only) and sunroof but not door locks or seats. And it isn't affected by disconnecting the battery unless they were working before hand -- not the other way around.
It sounds like an electrical problem. The car's computer constantly checks for problems. When you disconnect the battery the fault is temporarily erased but will come back eventually when the computer finds it. Maybe a grounding fault -- hard to say. It may be due to some feature you are using intermittently. Bear in mind, also, that locks are pneumatic and the seats are electric so there could be more than one issue involved.
Old Jan 19, 2014 | 01:31 PM
1999 e320
Guess I will have to take it to the dealer to have them scan it. Thanks for all the help guys
Old Jan 19, 2014 | 06:07 PM
RichardM98's Avatar
If you are in a metro area, you might look for a indy with SDS capability since it would probably be cheaper.
Old Jan 19, 2014 | 06:13 PM
1999 e320
First mb what is sds
Old Jan 19, 2014 | 06:36 PM
jtysin3617's Avatar
2001 ml320
Question
A i had the same problem with my 2001 ml320 i can resynch it and it would work for a little while but then everything goes out again. I had the AAM moduale replaced and it fixed the problem found out about the all activity moduale from this site actually a few years ago when i brought the car.
Old Jan 19, 2014 | 07:05 PM
1999 e320
Thanks will check that as well
Old Jan 19, 2014 | 09:20 PM
RichardM98's Avatar
Stands for Star Diagnostic System and is a proprietary computer system used to retrieve info from the car's computer. Some well equipped independent shops which specialize in MB also have them. Latest version also called DAS/Xentry.
Old Jan 19, 2014 | 09:34 PM
1999 e320
Thanks I'm bona check it out
Old Jan 20, 2014 | 07:42 AM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
Search for CAN Bus topics. A failure of one unit (like the rear window motor on mine) breaks the network communications and cuases the other modules to stop responding. You can troubleshoot it yourself by:
1. locate the CAN junction connector under the door sill, in the cable spaghetti below the A-pillar.
2. disconnect one of the 10 items, do a battery disconnect reset, and then drive around for awhile to see if the problem recurs. I would start with the right rear window motor.
3. repeat 2 until successful.
Old Jan 20, 2014 | 11:18 AM
1999 e320
Thanks sounds good hope it works I will let u. Guys know the outcome
Old Jan 20, 2014 | 11:39 AM
raymond g-'s Avatar
99 E320
if you feel so inclined you can also update your profile with more detail.
you never know when you might get lucky and have a fellow member
who is more knowledgeable, have same problem....even an SDS living nearby
Old Jan 20, 2014 | 12:00 PM
1999 e320
Done profile updated
