97 E420 idle issue
Old Apr 25, 2014 | 03:09 PM
omtara2's Avatar
1997 E420
97 E420 idle issue
Hi. I have a 97 E420 with 148,000 miles. While stopped at a light for about 1 minute, the idle drops, the car tries to stall but brings itself back. It has been doing this for awhile. Now, every once in awhile it will give a quick hiccough at low speed. It has stalled twice while pulling out of the driveway. It is not throwing check engine codes.
Here is what we have tried: plugs were fouled so changed them along with the wires. Crankshaft position sensor was changed. Mass air sensor was changed. We put in a different throttle actuator (tried 2, no difference). The fuel pressure was fine so fuel pump and filter were ruled out. Coils seemed to be fine. It has been hooked up to graphs and computers. Nothing shows as being wrong.
One other thing it occasionally does, which may or may not be related, is the yellow low fuel warning will start flashing despite having plenty of fuel. It goes away with a restart.
After the new plugs and all, the car runs great. Tons of power. Fun to drive. It's just this boggy idle thing! I am at the point of trying to decide if I should just sell it. I am hoping someone may have some advice. Thank you!!!
Old Apr 25, 2014 | 06:32 PM
MarkAd123's Avatar
1997 E420
Idle
Check your vacuum lines. I have one that tends to come undone and it results in the same issue. Someday I'll get around to replacing it.
Old Apr 25, 2014 | 10:27 PM
omtara2's Avatar
1997 E420
Thanks so much. I will look into that.
