2001 E55 Tires (W210)
Old Apr 30, 2014 | 12:34 AM
benzdirector's Avatar
ML500
Thumbs up 2001 E55 Tires (W210)
Does anyone know what the factory tire size is and which brand of tire it came with? I have a 2001 E320w with Monoblock II's on.
Thanks for anyone's input.
TJ.
Old Apr 30, 2014 | 11:22 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Most W210's were sold with 16" (7 1/2 J x 16 H2 ET41) and 215/55 R16 93H Michelin or Continental. 17" was an optional oversize. At some point (W211?) 17" became the std and 18" the upgrade. Assuming the wheels were factory standard (VIN data card) you can go to Tirerack and check on sizes for current tires since the ones that came on the car new are probably no longer made. Start by pulling a wheel and looking on the back for the size and offset (ET).
Old May 1, 2014 | 07:30 AM
SerbNerd's Avatar
2001 E430, 2002 ML55
Originally Posted by benzdirector
Does anyone know what the factory tire size is and which brand of tire it came with? I have a 2001 E320w with Monoblock II's on. Thanks for anyone's input. TJ.
I have the monoblocks on and the "stock" size would be 245/40R18 and 275/35R18...I believe. This would keep the rolling diameter the same so speedo won't read fast or slow.
I run 235/40R18 up front and "stock" rear size.
Stock tire brand will require a bit more research.
Find a tire size calculator and see what sizes would be best for you.
Old May 1, 2014 | 07:59 PM
Dave1965's Avatar
2001 E55, 2022 Corolla Hatchback XSE, 2024 RAV4 LE, 2024 F150 XL SuperCrew 4x2 3.5 Ecoboost
TJ.
On mine, it's mentioned on the Tire Pressure Placard on the Driver's Side Doorsill.
Old May 2, 2014 | 05:20 AM
matt72's Avatar
c124 124.051
235/40/18 front,265/35/18 rear,michelins
Old May 2, 2014 | 11:24 AM
renault12ts's Avatar
W215 CL500 2005
In the owners manual supplied with my car, which includes the E55, it says (as in the post above):
235/40 18 and 265/35 18.
If others say differently it's because they know better than me and Mercedes Benz.
Old May 2, 2014 | 04:45 PM
mufc's Avatar
2006 CLS55
Michelin stock and dunlop optional where stock tires in USA, though I never saw an E55 with Dunlops fitted. 245/40/18 and 275/35/18 front and rear respectively for US cars
Old May 2, 2014 | 04:47 PM
SerbNerd's Avatar
'Murica spec FTW
Got worried there for a second, was pretty sure that those were the specs. Didn't know EU had different spec.
