2002 E320 Slow Blower (question about regulator)
Old May 17, 2014 | 01:22 AM
rjay2140's Avatar
2002 E320
Hi Guys!
I'm trying to diagnose and fix this problem. I have a 2002 E320.
Symptoms: Low blower speed regardless of chosen blower speed. Air is cold. Sometimes it speeds up for a few seconds but then it goes back down.
Attemps to fix it: check fuses, check/clean cabin air filter, recharged R134a
Shop says: replace blower motor and quotes me $647
After researching on this, the blower motor regulator seems to be the problem. I want to try (it looks like I only need a philips screwdriver and a T-20) and fix this however I don't know what regulator to buy since there's apparently an early version and an updated version and I don't know how to discern the parts. I am pretty sure I need an updated regulator since I have a 2002 model. This is where I need help.
Regulator: how do I tell if the part I am buying is an updated version? I am probably going to buy through ebay or amazon.
Also apparently you can tell if your car needs the updated version through your car's VIN. Is there a website where I can input the VIN and find out myself or should I post it here?
Thanks!!! Sorry if it's a lot of information.
Old May 18, 2014 | 07:53 AM
gevange's Avatar
2000 e320
epc.net put in your serial #. This is the one I just put in my 2000 from Rock auto. HELLA 351321131 Blower Motor Control Module / Resistor $ 72.89 Works perfect.
Old May 18, 2014 | 12:35 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Handy link for you - parts - schematics - drawings
http://www.everythingbenz.com/z/mtyp...atics-drawings
It helps if you read Russian but you can use Google Translate...
This looks like your area:
http://mb.ilcats.ru/part/class/1/cco...e/065/group/83
Autohaus has the part:
http://www.autohausaz.com/search/pro...2002&cid=24@AC %26 Heat - Climate Control&gid=6557@Blower Motor Resistor/Regulator
Pelican Parts offering:
http://www.pelicanparts.com/catalog/..._pg2.htm#item7
Old May 19, 2014 | 05:55 PM
gevange's Avatar
2000 e320
WDBJF65J6YB058331 If you give me yours i will look it up on epc
