Height differences on different shocks?
Old Dec 6, 2003 | 07:45 AM
Whitey's Avatar
98 W210 Advantgarde
Question Height differences on different shocks?
My OEM shocks are about to expire and I was told if I used Eibach (as opposed to the Bilstein etc. shocks) I would get an additional 3/4-1" drop in the front which is what I need . Can anyone confirm whether different brands/types of shocks will give different heights with the same springs?
I'm beginning to think this is true as both Mtdceo and I had Eibach springs installed on stock (or other shocks) and found that the front was not lowered as far as the back. On the otherhand, Gary E430 had the entire Eibach lowering kit (springs and Eibach/sachs shocks) installed and his ride looks just right.
I have confirmed that the springs I'm using are the correct ones for my engine weight so it is not a case of the wrong springs being used.
Old Dec 6, 2003 | 01:38 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Hmmmm, good question. I am too curious to see if this is true...
Old Dec 6, 2003 | 01:56 PM
Whitey's Avatar
98 W210 Advantgarde
I'll let you know when the Eibach shocks arrive mid-next month - would you believe the fxcker tried to convince me that the setup wouldn't be complete without Eibach sway bars as well!!!!! I could do with a "figure width" drop on my fronts.
Old Dec 8, 2003 | 11:33 AM
Whitey's Avatar
98 W210 Advantgarde
Well, I've decided to bite the bullet with Eibachs - nobody seems to be sure except my mechanic (which I worry might just be a typical sales pitch since he's the authorized dealer).
Anyway, I understand the design of Eibach shocks are different to say Bilsteins in that they are inverted i.e. the "female" part (i.e. the stationary half) is on the bottom instead of the top on conventional shocks. Apparently this has the effect of creating a softer ride on the earlier parts, hence a smoother ride at low speeds and gets firmer as the movement becomes more abrupt - that would good....can't be sure tho', may just be another sales pitch.....
Old Dec 8, 2003 | 11:41 AM
Dang salesmen...
Old Dec 8, 2003 | 11:49 AM
zx11blade's Avatar
2001 E320, 2008 E63 AMG
And with the Bilsteins is there any drop or are they the same size as OEM?
Old Dec 8, 2003 | 11:55 AM
Whitey's Avatar
98 W210 Advantgarde
Like Jimmy says, dang salesmen One guy who only stocks Bilsteins said it would drop more than the OEM but didn't sound real sure - the guy had the nerve to tell me Eibach dont make shocks and never heard of Sachs! Damn ricer tuner! However, he did offer to let me install it first and promised I don't need to take them if I didn't like it........now that sounded too good to be tru......
Old Dec 8, 2003 | 12:07 PM
It sure does sound too good to be true. The only way that will work is if you don't sign anything, let him to the install and see if you like it, if you don't, make him take them off or just drive away. Either way you didn't sign or pay for anything, maybe you'll go away with some free *****... :p
Old Dec 8, 2003 | 12:31 PM
Whitey's Avatar
98 W210 Advantgarde
Unfortunately, he's in a very narrow dead end street and the only way out is to back out
Old Dec 12, 2003 | 06:36 PM
rp718's Avatar
1996 E320
Shocks don't change ride height, springs, pads, wheels and tires do.
Unless you have smaller springs, or same size springs rated for less weight (they compact more), nothing will change except ride quality due to different shocks. The dude's feeding you a line of crap.
Old Dec 13, 2003 | 01:14 PM
Like I said before, stupid salesmen...
