Question about pre facelift & facelift frontdoors.
So I'm now searching for a door and a fender, I got a fender but I'm thinking that it isn't a real piece, is there any way of confirming that it is an original Mercedes fender?
And my second question is about the door, is there any difference between the door of a pre facelift W210 and a facelift W210 if there are, how can I see this?
My car is from the beginning of 2002 so it's a facelift model and I'm worried that if I'll get an pre facelift model door that the leather interior or the mechanics in the window won't fit on the door, or am I just paranoid?
I'm going to buy the door trim seperatly from Mercedes, the door handle and the mirror will be used from the door that is on the car at the moment.
Is there any difference internally, the airbags, the windows mechanism, speakers and such. Also I'm going to put the interior piece over, so the leather plus the wood trim and the little speaker in the corner of the door are coming off the car and going to be put on the replacement door, will that fit if it is pre facelift.
Thanks in advance.
YD61
The cost should be zero if you're in North America.
you can check your local library to see if they have a copy of the Hollender Interchange
Manual and look it up in about 5 mins.
you can go to your local library to see if they're willing to contact another library which has
this book to check the information for you.
you can check with your dealer to see if they're willing to look this up for you
you can see if local Goodwill has Hollender.....or buy one off Ebay
you can check with you local wrecking yard to see if they have the Hollander manual and
i have a 1999 e320. i bought door panels from 02 and they fitted perfectly
