2001 e320 cooling fan not working?
diagnostics ive done.
checked fuses which all were good.
hooked up a multimeter to check voltage on the clip that is mounted on the shroud. only got .056 volts < noted that engine hadnt had time to get up to 95 C* but was at about 80-85 and i had AUTO On the A/C controls- still nothing??
not sure what other diagnostics i could do? what im doing wrong?
also in other forums i keep hearing the term "relay switch" where is the one on this car and what is its purpose?
Here is a link to our site if you need the cooling fan:
AutohausAZ - Cooling fans
Disclaimer: Make sure to check the year and model of the vehicle before placing the order.
and fuzes have been checked and they are good.
now it must be in the wires? or maybe even the ECU or whatever sends the signal to the fan???
not sure where the relay switch is?
and cant find a wiring schematic to save my life.
