city light H6W to match xenon headlight
I found an amber LED that I loved to use as a city lamp but removed it because I could never figure out the correct resistor rating to install and hated the defective lamp message.
Here is a link to the LED's I bought...
SuperBrightLEDs.com
SuperBrightLEDs.com
Mich and Whit
Mich and Whit
I had try those LED already, dont waste your time and money.
The LED does not look that great. The search still continue.
Steve
Steve
Originally posted by Whitey
Those are perfect Mich, just like the ones I found....lets just hope someone gives us the right resistor to get.....
98 W210 Advantgarde
Re: Mich and Whit
Originally posted by nguyensteve
Mich and Whit
Steve
Mich and Whit
Steve
#33
Steve, I just bought those bulbs you spoke about in your original post. I looked and there only seemed to be 3 choices for the H6W, the Phillips, the Osram (both of which people said didnt make much of a difference ), and then this one, which the seller says are bluer than those other 2 anyways....they should be here this week and I will let everyone know.
Hopefully it will work, LED's just same like a pain, especially if the warning light comes on for the bulb being out....just not something you want to screw with in a $50-100k car.
Matt
2000 CL
Matt
2000 CL
#35
2016 G63 ; 981 boxster GTS
lamin-x
Originally posted by The Doctor
Ok cheap way to do it: Why not just use a tint spray and tint the bulb itself, or use one of those "condom covers" that are colored and put one on?
the stuff is called 'lamin-x' can be found on the web.
here's the site.
good luck , j.
#36
Re: lamin-x
Originally posted by jago1244
after trying the philips h6w in the past, i went the cheap way on this and installed a bluish cover on the city lights that does improve the 'hue' of the lights. no longer yellow , and only the slightest loss of brightness. one side effect is when the city lights are off, the cover appears bluish , a slightly rice-y effect that may not fit all tastes , esp in certain colors. i like it on my black car though. i'll try to post pics this week. easy to install with a water/alcohol spray bottle and a hair dryer and a squeegie.
here's the site.
good luck , j.
here's the site.
good luck , j.
#37
98 W210 Advantgarde
Re: Re: lamin-x
Originally posted by michakaveli
convinence illumination feature
BTW, you still haven't found the yellow bulbs yet? I think Philips make them and they sure are more reliable than the Asian products.
#38
Re: Re: Re: lamin-x
Mich, what's that?
Mich, what's that?
#40
C43
Load Equalizer for LED bulbs
Here's a load equalizer to be used for the LED lights.
http://www.formymercedes.com/mb_resu...lacement+Bulbs
Load Equalizer, 6 Ohm
#650
Since the LED bulbs draw such little current, our exclusive load equalizers are required for proper functioning with turn signal applications, as well as with vehicles equipped with a "Bulb Out" warning system. Without the Load Equalizer, the "Bulb Out" system senses that a bulb has been burnt out (because of the low current draw), when in fact it has not. Without the Load Equalizer paired the turn signals, the system will flash the turn signal bulbs very rapidly, for the same reasons.
Installation simply involves attaching the load Equalizers with the quick connectors which are supplied, with one wire attaching to the positive and the other to the ground
installation1
installation2
Note: Be careful where you install Load Equalizers since they get very hot. If they don't appear to be working, make sure the connectors have pierced through the insulation on the wires.
#650
installation1
installation2
#41
Real Cars
Very interested as well. Checked that hoen-usa.com website and their "xenonmatch" H6W is on backorder. Has anyone used them?
That formymercedes site sells the load equalizer, but doesn't sell an H6W kit for the W210.
-m
-m
