E320 4matic saved from the scrapyard
Old 02-28-2015, 02:21 AM
amok55amg's Avatar
SL55AMG + SL600 + E320 + A180
Bought this E320 from 1999 with 290.000 km. (180.000) for 7.000 kr. ($800) and I guess if I haven’t bought it – it will eventually have gone to the eternal Autostrasse for Mercedes Benz cars ……
Have to put it back in shape …. takes time and coast money - pics. tells the most ……..
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5219.jpg   E320  4matic saved from the scrapyard-imgp5221.jpg   E320  4matic saved from the scrapyard-imgp5228.jpg   E320  4matic saved from the scrapyard-imgp5229.jpg   E320  4matic saved from the scrapyard-imgp5277.jpg
Old 02-28-2015, 02:23 AM
amok55amg's Avatar
more pics. 1
more pics. 1
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5278.jpg   E320  4matic saved from the scrapyard-imgp5281.jpg   E320  4matic saved from the scrapyard-imgp5297.jpg   E320  4matic saved from the scrapyard-imgp5298.jpg   E320  4matic saved from the scrapyard-imgp5299.jpg
Old 03-01-2015, 12:04 AM
raymond g-'s Avatar
99 E320
wow...good luck with your restoration project. it'll be a labor of love...and time !
Old 03-01-2015, 12:15 PM
amok55amg's Avatar
Oil leaks …..
gotta take care of those oil leaks …. new gaskets needed here …. and that’s all folks to fix this mess … nothing wrong with the engine …..
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5301.jpg   E320  4matic saved from the scrapyard-imgp5302.jpg   E320  4matic saved from the scrapyard-imgp5303.jpg   E320  4matic saved from the scrapyard-imgp5304.jpg   E320  4matic saved from the scrapyard-imgp5306.jpg
Old 03-01-2015, 12:19 PM
amok55amg's Avatar
more gaskets and rubber hoses etc. needed
will change all the way down to valve covers + new plugs …….
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5308.jpg   E320  4matic saved from the scrapyard-imgp5309.jpg   E320  4matic saved from the scrapyard-imgp5315.jpg   E320  4matic saved from the scrapyard-imgp5316.jpg   E320  4matic saved from the scrapyard-imgp5317.jpg
Old 03-02-2015, 02:22 AM
amok55amg's Avatar
new life ….
after cleaning and new gaskest
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5319.jpg   E320  4matic saved from the scrapyard-imgp5320.jpg   E320  4matic saved from the scrapyard-imgp5357.jpg   E320  4matic saved from the scrapyard-imgp5358.jpg   E320  4matic saved from the scrapyard-imgp5359.jpg
Old 03-07-2015, 01:19 AM
amok55amg's Avatar
Going for the painting the subframe
Not easy when you don’t have to work outside on the ground - but not impossible
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5391.jpg   E320  4matic saved from the scrapyard-imgp5394.jpg   E320  4matic saved from the scrapyard-imgp5401.jpg   E320  4matic saved from the scrapyard-imgp5402.jpg   E320  4matic saved from the scrapyard-imgp5407.jpg
Old 03-07-2015, 01:22 AM
amok55amg's Avatar
More pic. for subframe
Keep going on .... engine mounts replacements ..... the right one easy but the left .... puhhhhhh
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5409.jpg   E320  4matic saved from the scrapyard-imgp5417.jpg   E320  4matic saved from the scrapyard-imgp5429.jpg   E320  4matic saved from the scrapyard-imgp5441.jpg   E320  4matic saved from the scrapyard-imgp5445.jpg
Old 03-08-2015, 03:23 AM
amok55amg's Avatar
sub frame blasted and painted …. + some oil change …
project moving on slowly
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5448.jpg   E320  4matic saved from the scrapyard-imgp5452.jpg   E320  4matic saved from the scrapyard-imgp5461.jpg   E320  4matic saved from the scrapyard-imgp5463.jpg   E320  4matic saved from the scrapyard-imgp5464.jpg
Old 03-08-2015, 03:46 AM
amok55amg's Avatar
Working on the outside
have to improvise get it all back together again
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5470.jpg   E320  4matic saved from the scrapyard-imgp5471.jpg   E320  4matic saved from the scrapyard-imgp5472.jpg   E320  4matic saved from the scrapyard-imgp5473.jpg   E320  4matic saved from the scrapyard-imgp5474.jpg
Old 03-09-2015, 08:52 AM
giuseppesalvato's Avatar
E220cdi avantgarde
great job you are doing, especially doing it outside, you must get very cold, how long does it take for your fingers to go numb. what i would like to know is, where do you get the stands your car is resting on, I definately could do with a few of those as they seem to fit the rubber pads on the chassis and look very stable
Old 03-09-2015, 11:19 AM
amok55amg's Avatar
My finger doesn’t get numbed … I have Viking blood in my veins! ha ha ha
For the jack stands then I made them myself – easy to do – some plate and a pipe about ψ200 mm. and two types of square bars that goes within each other – drill some holes – some welding and wupti – you have some very stable jack stands …. (pipe is not thicker than 2 mm. – you can probably get some from a mill where they have corns and so ….)
another type of jack stands that is VERY stable I also made you can see in my other build thread: https://mbworld.org/forums/sl55-amg-...ml#post5526734
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5477.jpg   E320  4matic saved from the scrapyard-imgp5479.jpg   E320  4matic saved from the scrapyard-imgp5482.jpg   E320  4matic saved from the scrapyard-imgp5487.jpg   E320  4matic saved from the scrapyard-imgp5489.jpg
Old 03-09-2015, 11:27 AM
amok55amg's Avatar
Hydraulic systems and Diagnostic
Changing the filter for the hydraulic systems – as good as it’s possible ….. then some Diagnostic -
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5492.jpg   E320  4matic saved from the scrapyard-imgp5493.jpg   E320  4matic saved from the scrapyard-imgp5494.jpg   E320  4matic saved from the scrapyard-imgp5495.jpg   E320  4matic saved from the scrapyard-imgp5498.jpg
Old 03-10-2015, 05:49 AM
E220cdi avantgarde
do you have a job working in a machine shop, or do you have your own workshop, the tools you make yourself must save you a fortune, its great that you have knowledge to do everything yourself, and if you do'nt, you know where to look for it.
Old 03-11-2015, 04:42 PM
amok55amg's Avatar
No more bumby rides
I only have this little workshop you see on the pics. in my build … just for hobby but as there are a lot of guys working around this place on cars – American mostly – we always find a way to help each other ….. and for more small and special tools I make them at my work ….. as you say – there’s a lot of money to be saved by doing it yourself …… tools inclusive
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5525.jpg   E320  4matic saved from the scrapyard-imgp5526.jpg   E320  4matic saved from the scrapyard-imgp5527.jpg   E320  4matic saved from the scrapyard-imgp5531.jpg   E320  4matic saved from the scrapyard-imgp5532.jpg
Old 03-11-2015, 04:48 PM
amok55amg's Avatar
Air is coming in again ….. new blower (from the scrapyard) ….. also new shocks for the backdoor makes it as new again …… and a look at a OEM oil filter from my girlfriends car (E320) … reminds me that I will never go for something like this again ---- only MB stuff for what that’s concerned …
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5542.jpg   E320  4matic saved from the scrapyard-imgp5543.jpg   E320  4matic saved from the scrapyard-imgp5557.jpg   E320  4matic saved from the scrapyard-imgp5559.jpg   E320  4matic saved from the scrapyard-imgp5760.jpg
Old 03-14-2015, 06:29 AM
amok55amg's Avatar
driveshaft
As somebody knows I lost the driveshaft for the front wheel some months ago ….. https://mbworld.org/forums/e-class-w...ng-80-mph.html
and now’s the time to get under the car for real …. and it shows my repair couldn’t have hold on for much longer! …….
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5900.jpg   E320  4matic saved from the scrapyard-imgp5901.jpg   E320  4matic saved from the scrapyard-imgp5902.jpg   E320  4matic saved from the scrapyard-imgp5917.jpg   E320  4matic saved from the scrapyard-imgp5908.jpg
Old 03-14-2015, 06:34 AM
amok55amg's Avatar
Make-over underneath
little problem with the height of the lift … had to improvise to get the transmission down ….. gonna go for a make-over of gasket ….. so there will be no more “snail track” of oil after my car
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5920.jpg   E320  4matic saved from the scrapyard-imgp5922.jpg   E320  4matic saved from the scrapyard-imgp5923.jpg   E320  4matic saved from the scrapyard-imgp5927.jpg   E320  4matic saved from the scrapyard-imgp5929.jpg
Old 03-15-2015, 04:57 AM
amok55amg's Avatar
not easy to get down when the lift cannot go higher ….. notice the straps …….
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5931.jpg   E320  4matic saved from the scrapyard-imgp5932.jpg   E320  4matic saved from the scrapyard-imgp5934.jpg   E320  4matic saved from the scrapyard-imgp5935.jpg   E320  4matic saved from the scrapyard-imgp5937.jpg
Old 03-15-2015, 05:00 AM
amok55amg's Avatar
transmission and transfer case work-over
transmission and transfer case work-over .... big cleaning job ......
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5940.jpg   E320  4matic saved from the scrapyard-imgp5941.jpg   E320  4matic saved from the scrapyard-imgp5942.jpg   E320  4matic saved from the scrapyard-imgp5943.jpg   E320  4matic saved from the scrapyard-imgp5944.jpg
Old 04-05-2015, 01:38 AM
amok55amg's Avatar
taking it apart
moving forward …..
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5946.jpg   E320  4matic saved from the scrapyard-imgp5949.jpg   E320  4matic saved from the scrapyard-imgp5950.jpg   E320  4matic saved from the scrapyard-imgp5952.jpg   E320  4matic saved from the scrapyard-imgp5953.jpg
Old 04-05-2015, 01:43 AM
amok55amg's Avatar
Transmission pan
Bolts in the transmission pan were so corroded they broke …. wonder when it had a oil change …. oil was black …..
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5970.jpg   E320  4matic saved from the scrapyard-imgp5971.jpg   E320  4matic saved from the scrapyard-imgp5972.jpg   E320  4matic saved from the scrapyard-imgp5973.jpg   E320  4matic saved from the scrapyard-imgp5975.jpg
Old 04-05-2015, 02:10 PM
J spaulding's Avatar
1999 MB E430 1998 SL500
210 expert
By now hopefully you have decided to open up a shop called "The Sweden 210 Shop" and have all of that business in Sweden. How about a vacation to Seattle! We can have a drinking, talking and working get together. I get dibs on either the drinking or talking segment.
You have done a great job and I hope that you get another 500,000km out of it.
Old 04-15-2015, 02:35 PM
amok55amg's Avatar
almost there
thanks a lot for the invitation …. a might take you up on that one day ))
for the workshop …. well – I’m already using too much time on cars …. our own cars that it …. but always helpful non the less ….
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5978.jpg   E320  4matic saved from the scrapyard-imgp5979.jpg   E320  4matic saved from the scrapyard-imgp5980.jpg   E320  4matic saved from the scrapyard-imgp5981.jpg   E320  4matic saved from the scrapyard-imgp5983.jpg
Old 04-15-2015, 02:37 PM
amok55amg's Avatar
no stopping me ....
ahhhhh ....... so easy ......
Attached Thumbnails E320  4matic saved from the scrapyard-imgp5986.jpg   E320  4matic saved from the scrapyard-imgp5988.jpg   E320  4matic saved from the scrapyard-imgp5990.jpg   E320  4matic saved from the scrapyard-imgp5991.jpg   E320  4matic saved from the scrapyard-imgp5993.jpg
Quick Reply: E320 4matic saved from the scrapyard
