Parktronic problem
1999 w210 E240
Parktronic problem
Hi! How are you folks?
I have a strange error (at least for me), when I start the car the pts system gives the two red lights error, so I thought that a sensor was broken.
I connected to carsoft and I tell me that it can't communicate with the pts module.
So the question is: Is my parktronic ecu broken? Or just the carsoft that can't communicate?
Thanks in advance.
PD: 1999 e240 and carsoft 7.4
Thanks in advance.
1999 w210 E240
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Is this the complete story, as you surely must have hooked up before and ran a "Quick test" and at that time you would have seen the i in PTS box indicating no communication.
When you double clicked the i in the PTS box what did it say and were there any other i on the quick test.
PS: you did check fuse 15 in the fuse and relay box
1999 w210 E240
Yes I hooked up and run a quick test, PTS,Airmatic and DMC (fl,fr,rl,rr) ECUs didn`t respond (dont have airmatic and DMC 1,2,3,4 did respond).
Tried to do a live data but again, PTS module is not build in or does not respond.
I did check all the fuses and they were ok.
PS: ME,ABS,AIRBAG,BAS,Cluster,EGS,AIRCO,PSE,SAM,OCP,LC P,D2B and EIS respond ok, the only module that is build in and doesn`t communicate is PTS.
After the quick test and you got an i for the PTS did you double click on the i and get any more information-----like issues with the module or issues with sensors or anything--just a yes or no
Because if you got nothing then I would go out on a limb and say you have a faulty module and would not take the car to the dealer----but do yourself a favor don't by junk yard seconds and get a new unit---then the issue is will Carsoft do adaptions because the module has to be mated to the car using HHT/DAS.
