Considering StrutMasters Conversion
I'm a retired auto tech so I know my way around, but I don't have access to a lift, so I'll be doing this in my garage and on my back.
You're responses are appreciated, but please keep it on the subject and hands on experience is what I'm after, not hear say.
Thanks to all,
James
Package arrived and parts looked nothing like the video or on website.
Instructions were for 2003-2006 models with air ride. I called Strutmasters and technician said they "modified" the kit and the shocks and springs in the kit were a better fit than the old style. Problem is the shocks have mounting stems on both ends! The tech said they included a drill bit and I should drill a hole in my lower control arm to mount the shock! Also the springs don't have the correct ends and although they provide a lower mounting adapter, I can't see how the spring would seat properly in the upper spacer. Needless to say, the kit is going back and they're refunding my $$.
I still want to remove the SLS and put a conventional set up to maintain original height. I've searched but can't find specs on the OE springs. I know the SLS cars are said to have lower rated rear springs because the hydraulic units are carrying a lot of the load, so once they're taken out, can't just replace the shock absorber with a conventional one. (rear end sag most likely the result) I'm researching to find a replacement spring/shock combo that will work. Anyone have any info to share?
Most of the guys on here have experience in lowering their cars or with coilovers. Not too many wagon guys. Check out peachparts.com. I have found that many of those members have eliminated SLS on their wagons.
(I thought about using air-shocks but the shocks diameter would rub against the sway bar links)
I removed the 5.5" bags and replaced them with 8" bags. Problem solved. Car rides better than ever and ride height is perfect. I posted a complete write up with pictures on the "other" Benz forum with part numbers and instructions, if anyone is interested.
sullojames@gmail.com and I'll try and help you out if need be.
