Intermittent Starting Problem
Old Dec 8, 2015 | 02:36 PM
Rich9300's Avatar
2019 AMG E53
I have a 2001 E55 but this problem would relate to all E-class cars of the era.
I began to have occasional starting problems a couple of years ago. When I
turned the electronic key the car would not turn over - there was some brief
noise but it wouldn't turn over, though eventually it would start. This happened
only occasionally but I asked my independent repair shop about it and they
recommended replacing the electronic ignition to be on the safe side. I did - it
cost about a thousand. After a short while the problem began to recur
occasionally. Now I thought maybe it has to do with the shift lever and tried
jiggling it. That seemed to work - eventually it would start. However, I was still
afraid of getting stranded somewhere so I asked the dealer to look at the shift
mechanism. They replaced the floor shift assembly and i thought this time it's
got to be fixed. No such luck. Tonight I again had the starting problem. If a
new ignition system and a new floor shift didn't do the trick, what could it be?
Old Dec 9, 2015 | 07:56 PM
MacVidMB-V8's Avatar
W209, W124
Do you have 2 keys?
Could be a flakey smart key.
Curious about exact meaning of this:
"there was some brief noise but it wouldn't turn over, though eventually it would start."
When I say "turn over" I mean the engine is being spun by the starter, maybe you mean something else?
Old Dec 10, 2015 | 12:45 AM
Rich9300's Avatar
2019 AMG E53
Originally Posted by MacVidMB-V8
Do you have 2 keys?
Thanks for the response. Yes, by turn over I mean that the engine is being spun by the starter. The brief noise is a bump lasting just a fraction of a second. This morning when the engine was cold and the temperature was about 45F, I heard 4 quick bumps in succession before the starter cranked the engine. After a short drive and 10 minutes inside a store, it started after 3 bumps. Then after another short drive and 5 minutes inside another store, it started after one bump.
I don't think it's the key because it happens with both of my smart keys.
Old Dec 12, 2015 | 02:12 AM
E42AMG???'s Avatar
E420
I would make sure you have good battery voltage and cranking amps is the problem only when it sits for awhile?
Old Dec 12, 2015 | 04:11 AM
Rich9300's Avatar
2019 AMG E53
I had the car serviced today and the repair shop found the battery "was testing over capacity, likely internal short of battery cells." The battery was two years old and has now been replaced. I'll follow up in a couple of weeks to report if the new battery has resolved my issue.
Old Dec 17, 2015 | 12:08 PM
Rich9300's Avatar
2019 AMG E53
t
The new battery resolved my starting issue. The old battery was only two years old but I must have screwed it up somehow when I gave my wife's car a jump start. I had done that twice, I think, on the old battery. Now I bought one of those portable battery jumpers so that I don't have to use my car again.
Old Dec 17, 2015 | 11:37 PM
E42AMG???'s Avatar
E420
Glad you resolved the issue!!!
I have a portable jump pack and it was the best investment ever.
