$3,000 oil leak?
Old Feb 18, 2004 | 02:16 PM
mlicata's Avatar
Mercedes Benz E320
$3,000 oil leak?
The harmonic balance piece on my E320 came apart and ground metal on meatal. There is now a gap in my upper oil pan and timing front cover. The parts are only $380, but the repair center is estimating 30 hours of labor to replace the two parts, bring total close to $3,000. Has anyone ever had these parts replaced, and if so did it cost that much in labor?
Old Feb 18, 2004 | 02:38 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Re: $3,000 oil leak?
Call MBUSA ..ASAP And Have them GOODWILL This....Its a KNOWN Problem
http://www.mercedesshop.com/shopforu...threadid=63512
Old Feb 18, 2004 | 07:49 PM
The Godfather's Avatar
4 wheeled car.
Ouch puta!
It's a known problem as Mark said. I had them replaced on all 3 of my Mercedes as preventive maintenance.
Old Feb 18, 2004 | 07:56 PM
dduke's Avatar
'99 ML430
Same thing happed on my ML. Now it has a slow leak. $3000 will buy a lot of oil. They may cover parts as part of a "goodwill" gesture. That's the easy part.
Old Feb 18, 2004 | 08:45 PM
redcoupe's Avatar
11 ML350
Have fun trying to get them to GoodWill that. I had a SL with 14,000 miles on it and they wouldn't help that much.
If it didn't get it that bad, then some times they don't leak, if you got it early.
Brian
