Transmission Fluid
Old Dec 12, 2015 | 11:19 AM
Flyboy82's Avatar
95 SL320
Transmission Fluid
I read where you have to use Mercedes Transmission fluid in the 722.6 Transmission , is this true..? Thanks for any help.
Old Dec 13, 2015 | 01:54 PM
nelbur's Avatar
1997 E300D
This transmission was installed in non-MB cars, like some Chrysler products, so I am sure they do not need to use MB fluids. MB says the fluid should meet spec. 236.10. I am using a Valvoline atf with that spec. listed on the back of the bottle.
Old Dec 13, 2015 | 02:54 PM
Flyboy82's Avatar
95 SL320
Great Thanks.
Old Dec 13, 2015 | 08:22 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
I experienced that MB fluids are superior to the competition and even I could not test them all, I am not taking pushing my luck for $10 or even $20 savings.
Suppose Shell 134 is good, but than how much you can save on buying substitutes?
Old Dec 13, 2015 | 10:47 PM
Flyboy82's Avatar
95 SL320
Hey Kaj..I noticed you have a E320 Wagon..I have a E320 Sedan...I've got a problem..the SRS light is on all the time.
Old Dec 14, 2015 | 11:43 AM
kajtek1's Avatar
Seek the forum or start new topic.
On W210 broken wire on passenger seat sensor is common problem at some age.
Old Dec 14, 2015 | 01:01 PM
kajtek1's Avatar
Originally Posted by Plutoe
The main point is that you should use fluids that meet the design specification for the transmission----if the fluid meets the MB spec you are in good shape!!
That come from the member who is well known spammer ban on several sites for crossing the ethics.
When MB does allow substitutes, they are still substitutes.
The differences can be subtle, but for years I am observing that each time MB owner comes to a forum with overheating problem - he is using Zerex substitute not MB coolant.
Something that we can't measure right away, but I am using MB coolants even in my Ford Trucks as they cool the engine with no need for fans.
Also I drove E300DT for 4 years with engine fan removed, hitting 114F on deserts without overheating.
Something people like Plutoe will never understand.
Old Dec 14, 2015 | 01:07 PM
Flyboy82's Avatar
95 SL320
Talking
Thanks for the info:
