Airbag Problem
Old Dec 14, 2015 | 12:39 PM
Flyboy82's Avatar
95 SL320
Airbag Problem
I have a 1999 E320 that the Airbag Light on the console says "Airbag Off". and the SRS light on the dash is on all the time. I understand there is a sensor in the passenger seat, that may have a broken wire. Where is this located and what does it look like and should the battery be disconnected when I'm messing with this...? Thanks for any help.
Old Dec 14, 2015 | 01:04 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
There is good pictorial on the net, so if you won't find it with google, PM me as I don't want to post links to competition.
You will have to remove seat and pull the skin for full access.
Old Dec 14, 2015 | 01:10 PM
Flyboy82's Avatar
95 SL320
Angry
That sounds like funnn !!!
Old Dec 14, 2015 | 01:17 PM
kajtek1's Avatar
It is not that difficult and will give you a chance to collect the coins you dropped down there years ago
Fixing the wire might not be that easy as mine broke close to the sensor and took me a while to figure it out. Than you need very flexible wire that will not break in few weeks.
Now I would try to find cheap replacement on ebay and plug it under the seat to make sure this is your actual problem.
Other way would be hooking up SD, but that at dealers cost more than new sensor.
Old Dec 14, 2015 | 01:25 PM
Flyboy82's Avatar
95 SL320
I've only had the car for a couple of weeks, fixing everything they neglected. Is the tutorial on youtube..?
