Hi/Low beam malfunction
Old Feb 23, 2004 | 01:19 PM
rp718's Avatar
1996 E320
One of my hi beam/low beam bulbs does not light up when on the low setting - it lights up only when the brights are turned on. I assumed it was a bad bulb, so i changed it, but still no improvement. I jiggled all the connectors in the housing, but it's still not working. Any suggestions?
Old Feb 23, 2004 | 07:50 PM
redcoupe's Avatar
11 ML350
Are you talking about one of the small lights in the middle by the grill.
Becasue if you are there are two different bulbs in there, look with a flash light, there is a small bulb under the bulb you replaced.
Brian
Old Feb 23, 2004 | 07:56 PM
rp718's Avatar
1996 E320
Yes, the small lens.
I specifically asked the MB parts idiot if there was more than one bulb, and they said no and gave me the large (headlight) bulb.
Old Feb 23, 2004 | 07:57 PM
rp718's Avatar
1996 E320
I did see the connectors for what you're saying is the small bulb, but I couldn't seem to remove it. Twist? Pull?
Old Feb 23, 2004 | 09:08 PM
Whitey's Avatar
98 W210 Advantgarde
Now I get your problem. Just twist slightly and pull out - its clipped on - but be careful the clip can be brittle. The bulb is H6W - very cheap. Good luck!
Old Feb 23, 2004 | 10:31 PM
redcoupe's Avatar
11 ML350
Yes be very careful they break really easy.
