Carlsson Wheels fitting
Old Mar 6, 2004 | 12:03 AM
kicker's Avatar
E320 2000 w/GPS
Guys,
Just bought a set of Carlsson 2/6 18"x8.5 wheels with 235/40/18 tires. It has a ET35 offset 115, how is the clearance in the front ? Do I need to roll fenders? It came with 14mm x 1.5 lug bolts. I need to go get the 12mm before I mount them, or just use the one took of the stock rims. any ideas? Has any body able to find wheel locks to lock down these wheels? thanks.
Old Mar 6, 2004 | 03:10 AM
hubert's Avatar
14'G63 AMG ,1994 Mercedes E500, 2020 Range Rover HST
No you dont need to roll your fenders for 18" and with lug bolts call Luke @ Tire Rack he also might help you with locks for your wheels.
HUBERT
Old Mar 6, 2004 | 03:22 PM
kicker's Avatar
E320 2000 w/GPS
Sorry, it's 18x9 brilliant edtion. I just got it and could find any store thay carries cone seated 12mmx 1.5 w/28mm Shank 52mm Overall. Also this wheel didn't come with any adaptor for the valve stem. Does any one know where to order one to pump the air in.
Old Mar 6, 2004 | 03:47 PM
hubert's Avatar
Carlsson its your option i think.
Old Mar 7, 2004 | 12:19 AM
E-Klasse's Avatar
W205 C300
Try this place:
www.prestigewheel.com
You can't put a 14mm bolt in a 12mm hole and your OEM bolts should have a ball seat and you said your new wheels have a cone seat. So it sounds like you will need new bolts.
