AC Problem/ P1570 Code
Old Jun 8, 2016 | 09:11 PM
Flyboy82's Avatar
95 SL320
Is there a AC relay or fuse for the 99 E320 sedan..? Cannot find anything on the form that is with the fuse box.
My compressor is not coming on, but it was coming on just a couple of days ago.
Thanks for any help. I'm also getting a P1570 diagnostic code says it a fault in DAS to engine control module..Anyone know what this means..?
Thanks for any Help
Old Jun 9, 2016 | 11:10 AM
Flyboy82's Avatar
95 SL320
AC Fuse
There is NO fuse allocated for the AC system on my W210 I don't even see relay for the Compressor. Doesn't make sense.
Old Jun 9, 2016 | 11:17 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Do you have screen fuse or relay on your computer?
Did you try to clear the code and it come back?
Before going into parts dropping, cleaning all the plugs with MAF or other cleaner might help.
Do sensor readouts per recommendations and post here.
Old Jun 9, 2016 | 11:29 AM
Flyboy82's Avatar
95 SL320
Yes I erased the codes and it came back.
Old Jun 9, 2016 | 01:52 PM
Flyboy82's Avatar
95 SL320
No..I know that..just trying to kill 2 birds with one stone..
I have even a bigger issue now I can't get my ac compressor out, Ive evn tried to get the power steering pump pulley off but can't do it either I csn't even get the power steering pump off period. I can't even get the low and high side hoses off the compressor..no room for the tools..This is not my day. Thank you all for your input.
