suspension question
thanks guys
I now have Eibach+Bilstein Sprint Shocks.
As you know, the rear was dropped quite a bit too much with the Eibach srpings (a few members with Eibach springs experienced that too). I've had #1 pads in the front and moved up to #4 pads in the rears (from #3) just last weekend. Now it looks much better than before but this set up will not give you the slammed look (I try to take some pics of the new setup later this week).
As for performance, it is quite a good balance between comfort and performance - Eibach springs are meant remain comfortable at low speeds and becomes stiffer at hi-speeds.
Judging from pics, Jimmy's H&R+Bilstein set up seems lower than mine.....
This probably won't help much since I know Jimmy swears by his set up, but I've tried to be as objective as I can.....good luck!
I like it because it's low, and comfortable. But compareted to a W202 and W124 w/ HR/Bilstein setup, it's not as stiff.
Roll the fenders and there will be no problems.
dave shoot me over some pics
Doc, since it has a significant impact here, just for the record, can you tell us what wheel width and offsets you're running right now.
To be honest though, if you're looking for a very smooth ride you might want to go Mike's route with the cupkit. I've ridden in Mike's car and it's very smooth compared to mine. Don't get me wrong I don't bounce all over the place but I do feel the road a bit more than the cupkit and I like that.
Good luck with your decision Alex and make sure as Hank said, that if you decide to cut your springs to have it done the right way.
But yeah, the rear is really low ever since I got the Eibachs on (tires slightly tucked under the fender arch with #3's) .....why don't we take a pic of the side and measure clearance for Alex? However, sounds like the Cupkit is a good option - smooth but low..... errr but fender rolling needed?
From memory, with the new #4 in the back, mine looks sort of close to yours, except maybe the front is sitting a bit higher, with the #1 pads and even when I'd removed the dead body from the trunk (I really do have a load in there). It must be those darn Eibach springs - I heard the later Eibach springs tended to be higher in the front for some strange reason (I think even the skinny Dutchman also had this problem on his W202). Lets see when I take a pic........
BTW, what are Bilstein SP Sports? Is that the Sprint shocks I have? I've been told there's a Sport and the Sprint version, the latter having a longer travel allowing for a lower drop with a weaker spring...or something like that - that's why I got them. Both look exactly the same (only the part # is different).
well my fenders aren't pulled anymore, longgggg-story but i will find out today what to get, most likly the cupkit since once i throw in the supercharger this car won't be a daily driver...........
I guess you won't need the pics from me then? But also remember, in case you're not aware, get the springs that are for your engine weight.... they are different.
Heeeeay Jimmy! Sitting pretty...kinda even all round and very little gap
Yeah, my front sits just a hair lower than the rear and it's perfect for me. When I experimented with #1's before I was tucking tires so I didn't care for that look much.
I want to lower my car without compromising.
Jimmy - thanks for the lead on the mirrors (Steve in NL).
-Chris
www.ck-r.com
What in the hell is everybody talking about? Cupkit? #2, #4? Help a brotha' out.
-Chris
www.ck-r.com
So, you want to lower your car without comprimising what, the floaty ride, lol? You are going to definately feel the difference once you alter your suspension and IMO, it's for the better!
No prob. on the mirrors, Steve is the man...
#'s1,2,3,4 springpads => different thinkness of rubber pads/washers that sit on the end of the springs that allows you to lower or raise without changing the springs - lower number = thinner pad. Difference between each # is about 3-5mm. Mine came stock with #3 all round. Hope this helps.....
Yeah, Steve MBenzNL is da man!
H&R Cupkit => suspension system from H&R
