Old Jun 4, 2015, 08:11 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior
Print Wikipost
Door Panel Trim Removal/Speaker Install
Old Mar 21, 2004 | 11:41 PM
BritBloke's Avatar
E430 Sport
Question Door Panel Trim Removal/Speaker Install
Hi Everyone -
I just bought a perfect MY'00 E430 Sport with only 26K miles, silver on black, and I am looking to upgrade my stock stereo system similar to 'Matt's Mercedes Benz' - he did an awesome job, check out the following:
http://www.sounddomain.com/memberpage/133487/1
and the first job I need to tackle is replacing the door speakers, front & rear, also using the 'stock' tweeter fitting in the 'A' Pillar trim, 'behind' the rear-view mirrors for the front component set-up.
Trouble is, no-one seems to be able to tell me exactly WHAT size speakers are direct drop-in replacements for the door speakers, nor do I have the first clue how to successfully remove the door trims/A-Pillar trim without damaging them to get at the speaker locations!
Any advice or help would be very much appreciated...(pictures showing me how would be fantastic!). FYI, I plan to make a step-by-step photo documentary of the install to help out all the other poor slobs like me who don't have a clue. THANKS!
Cheers for now,
Old Mar 22, 2004 | 12:20 AM
EddieGTP's Avatar
Not a Benzer anymore
Check out my site with the W210 MB CD...
www.edsoto.com
then click on the MB Informational CD.
Good Luck!
Old Mar 22, 2004 | 08:35 AM
stemags's Avatar
2014 E550 4matic,, sold 2012 E 350 4matic,,sold 2010 e350 4w,sold 2002 e320 se
The panels can be easily done if you do a search in the various forums.Like you I didnt rip many door panels off German cars.But I recall a picture and step by step thing.
Old Mar 22, 2004 | 08:38 AM
stemags's Avatar
Wait... found it
Remove the Plastic Insert at the Door Handle release.Pops out
remove the screw behind it(Phillips)
remove the SRS plastic cover
remove the round cover at the lower panel area above the door pocket
remove the phillips screw behind it
remove the TWO phillips screws@ plastic cover at the door lock
Insert a PLASTIC wedge or covered screw driver to POP the Lower door panel then lift up and then unplug the seat controls and remove the inner release cable from the door..pops off
then you will see the Torx screws for the handles
Old Mar 22, 2004 | 05:43 PM
BritBloke's Avatar
E430 Sport
THANKS Stemag & Eddie - I'll give this a try on the weekend...but very delicately! Once I feel more confident I'll start posting pictures etc. for the full install (just in case anyone else is interested).
Cheers for now,
Sacha
Old Mar 23, 2004 | 02:03 PM
fatchance's Avatar
E430
You may want to invest in a door panel removal tool if you don't want to break too many of the door panel fastners.
i bought a set from a site called equalizer. Good quality tools and I didn't break any fastners!
The fastners are not cheap, about 1.75 each for a silly little piece o' plastic.
BTW, just finished a complete install of the audio system. A huge improvement over the stock bose system.
Front speakers are 6.5 coaxial
Rear doors are 3.5 inch single cones
Rear deck speakers are 6.5 2 ohm drivers.
(didn't have any factory tweeters in the a-pillar so don't know what size these were. I used the Focal TN-45 tweeter for the install)
good luck.
-travis
