Engine Electronics warning!!
Old Apr 12, 2017 | 10:33 PM
Agmerc's Avatar
E420
Good evening,
After washing the engine bay covering all electronic components I started the car and I got a check engine light on. The warning message engine electronics popped up on the screen and the car would Rev and shake on idle. Any ideas what could of gone wrong now? I checked all the spark plugs the maf sensor the fuel injector connections and nothing. I have a 1997 E420
Old Apr 13, 2017 | 11:37 AM
raymond g-'s Avatar
99 E320
"I checked all the spark plugs the maf sensor the fuel injector connections and nothing."
can you be more specific and detail clear what this means?
Old Apr 14, 2017 | 12:01 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Per my experience "electronics" was PPS, but could be more.
Check Codes.
Old Apr 14, 2017 | 02:10 PM
Agmerc's Avatar
E420
Well the car finally threw a code for misfire in cylinder 4 so I took out the coil and it was soaked in water, big mistake spraying the engine bay. Anyway I dried everything off and it's all working fine now and I have a Shiney ish engine bay!!
